[QGIS-Developer] Attrribute forms: widget frames are missing.
Nyall Dawson nyall.dawson at gmail.com
Mon Oct 8 15:30:40 PDT 2018
On Mon, 8 Oct 2018 at 18:40, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> I noticed that in the attribute forms in master, the frames of the widgets are missing, except for relation reference widgets.
> See screenshot in this mail - the widgets around the "1" (Anzahl Sonden), "112" (Bohrtiefe [m]", etc. should have frames.
> This is on Windows 7.
> Any idea what might be wrong here? Maybe a side-effect of the recent change where the gray parts of "read only" layers were replaced with black?
This was an intentional change -- see discussion at
https://github.com/qgis/QGIS/pull/8064
But it needs further work, for instance it's only fixed line edit
widgets, and like you've noted, the NULL representation needs work.
Nyall
> Note also, that the "NULL" in the text editor widget still appears as gray instead of black.
> Thanks for having a look at this as well!
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
