[QGIS-Developer] Attrribute forms: widget frames are missing.
Andreas Neumann a.neumann at carto.net
Mon Oct 8 22:55:36 PDT 2018
Hi Nyall and devs,
I have seen this discussion - but on Windows it currently looks really,
really bad. The is no distinction if something is a label or a widget,
which is quite bad in my opinion, as we have the option to hide labels.
How can the user then know if something is a widget or a label?
I will add my comments on github.
Thanks,
Andreas
On 2018-10-09 00:30, Nyall Dawson wrote:
> On Mon, 8 Oct 2018 at 18:40, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> I noticed that in the attribute forms in master, the frames of the widgets are missing, except for relation reference widgets.
>> See screenshot in this mail - the widgets around the "1" (Anzahl Sonden), "112" (Bohrtiefe [m]", etc. should have frames.
>> This is on Windows 7.
>> Any idea what might be wrong here? Maybe a side-effect of the recent change where the gray parts of "read only" layers were replaced with black?
> This was an intentional change -- see discussion at
> https://github.com/qgis/QGIS/pull/8064
> But it needs further work, for instance it's only fixed line edit
> widgets, and like you've noted, the NULL representation needs work.
> Nyall
>> Note also, that the "NULL" in the text editor widget still appears as gray instead of black.
>> Thanks for having a look at this as well!
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181009/a003678e/attachment.html>
More information about the QGIS-Developer mailing list
