[QGIS-Developer] Changing mAction.svg
Andreas Neumann a.neumann at carto.net
Tue Oct 23 23:29:59 PDT 2018
To add a bit more information (concretise) the situation:
this mainly concerns actions that do not have a different icon
associated, and therefore still display the standard blue cogwheel with
the arrow.
The question remains open if the icon should stay blue (if inactive) and
switch to yellow if active and no other icon is associated with this
icon.
I know that yellow is associated with selections, but isn't an action
also kind of a selection (single klick) with an immediate action after
the selection?
Andreas
On 2018-10-24 07:57, Andreas Neumann wrote:
> Hi,
> I'd like to change the color in the "mAction.svg" icon from blue to yellow (or some other color, if you have a better idea). Would people be ok with this change?
> It concerns https://github.com/qgis/QGIS/blob/master/images/themes/default/mAction.svg
> Reason: better distinguish this icon from the icon https://github.com/qgis/QGIS/blob/master/images/themes/default/mActionIdentify.svg
> People are frequently mixing up these two blue arrows.
> Thank you for your feedback,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181024/93b3dd33/attachment.html>
More information about the QGIS-Developer mailing list
