[QGIS-Developer] Unable to export map with PyQGIS 3
Dimitris Kar
dkarakostis at gmail.com
Wed Oct 24 00:47:20 PDT 2018
I am trying to learn and work with PyQGIS 3.
It is a very challenging task cause documentation is really [limited and
out of date][1].
What I am trying to do is to:
1. create a project
2. add a layer
3. save the project
4. export it as a png
I have done the first 3 steps (see code below).
import sys
import qgis
from qgis.core import QgsVectorLayer
from qgis.core import QgsApplication
from qgis.core import QgsProject
from qgis.core import QgsMapRendererJob, QgsMapSettings
from qgis.gui import QgsMapCanvas
from PyQt5.QtGui import QImage, QColor, QPainter
from PyQt5.QtCore import QSize
# PYTHON APPLICATIONS
# prefix path: the location where qgis is installed in the system
# the easiest way to find the prefix path to run the following commaand
from the python console of qgis: QgsApplication.prefixPath()
#1. CREATE THE APPLICATION
QgsApplication.setPrefixPath('/usr', True)
# second parameter into false disables the gui
qgs = QgsApplication([], False)
#load providers
qgs.initQgis()
#2. CREATE THE PROJECT
# create project
project_name = '/home/dkar/workspaces/qgis/data/test_project_2.qgz'
project = QgsProject.instance()
new_project = project.write(project_name)
#3. READ/OPEN THE PROJECT
# modify the project e.g. adding more layers and save it.
new_project = project.read(project.fileName())
#4. ADD A VECTORLAYER
# add a layer in the QgsProviderRegistry
layer=QgsVectorLayer("/home/dkar/workspaces/qgis/data/pakistan_1.shp",
"pakistan", "ogr")
if not layer.isValid():
print("Layer failed")
#5. ADD LAYER TO THE REGISTRY
project.addMapLayer(layer, True)
project.write('/home/dkar/workspaces/qgis/data/test_project_2.qgz')
#6. SAVE THE PROJECT
all_layers = QgsProject.instance().mapLayers()
img = QImage(QSize (800, 600), QImage.Format_ARGB32_Premultiplied)
# set image's backgroud color
color = QColor(255, 255, 255)
img.fill(color.rgb())
#create painter
p = QPainter()
p.begin(img)
p.setRenderHint(QPainter.Antialiasing)
# THIS IS WHERE THE ISSUE APPEARS
render = QgsMapRendererJob() # THIS IS WHERE THE ISSUE APPEARS
# set layer set (am I using here the prohect?)
lst = [layer.id()] # cause "layer" is the name of the variable
render.setLayerSet(lst)
# to remove the provider and layer registries from memory
qgs.exitQgis()
But when I try to do the last part, following the instructions from the
existing documentation. I get issues because the specific function
(`QgsMapRenderer`) doesn't exist anymore in QGIS 3.
I am not sure how to solve the issue.
I see in the documentation that this function:
QgsMapRenderer
was replaced by
QgsMapRendererJob
But then when I try to import and use it in the code as:
I get an error message:
TypeError: qgis._core.QgsMapRendererJob represents a C++ abstract class
and cannot be instantiated
Any idea how to proceed with this?
[1]:
https://docs.qgis.org/testing/pdf/en/QGIS-testing-PyQGISDeveloperCookbook-en.pdf
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181024/b6e53af8/attachment.html>
