[QGIS-Developer] Zoom to selected point (if only one point is selected)
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Oct 24 09:04:31 PDT 2018
I guess that in terms of end user experience, the definition of a setting
would perform the best.
But
- it's one more setting
- the chance that it is not set or correctly set is big
Maybe, the approach would be to fetch the canvas content and determines
that ones needs to zoom out so that the symbol is not overlapping others or
that there is sufficient screen width from its neighbours?
Denis
Le mer. 24 oct. 2018 à 04:27, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi,
> Given a layer with POINT geometries, if only one point is selected, QGIS
> doesn't zoom to this point, but only pans to the point so that the point is
> in the center of the map canvas.
> Now, I know that a single point does not have a dimension - but I still
> think that the current behavious is not user friendly.
> As an example: if your zoom level is at the whole dataset (many kilometers
> wide), and QGIS only pans to that single point, it is almost impossible to
> find that point.
> How can we solve this issue? Here are my ideas:
> a) QGIS points to a fraction (say 1%) of the overall width of all layers
> in the project and uses that 1% width and pans to the point
> b) The user can define a map scale that QGIS should use when zooming to
> that single point
> c) a combination of a) and b): if b) is set in the project, use the
> setting, if not set, use the mechanism of a)
> What are you thoughts?
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181024/c1e55950/attachment.html>
