[QGIS-Developer] What to do about WFS test failures?
Even Rouault even.rouault at spatialys.com
Mon Sep 3 12:29:35 PDT 2018
Régis,
Not that I'm against improvements, all the contrary, but just wanted to
underline that the provider was seriously refactored already in 2.16. Clearly
the lack of WFS-T support for 1.1 and 2.0 in the scope of those enhancements
can be a source of confusion currently for users. What do you have in mind as
refactoring exactly ?
Even
> Hi all,
> I very much think that the WFS client is an really bad state, and is not
> really reliable, especially in WFS-T context.
> The good news is that we just have been funded to refactor it !
> The work should start in september and land in 3.6. I will let our dev's
> come here with more technical details about the goals. I hope we will also
> be able to take benefit of this to this the OGC compliancy of the client
> here.
> Best regards,
> Régis
> Le lun. 3 sept. 2018 à 11:36, Tom Chadwin <tom.chadwin at nnpa.org.uk> a
> écrit :
> > I can't offer any helpful suggestions, but just to let you know I finally
> > had
> > to disable all my plugin WFS tests. I used to cope, by rerunning failed
> > Travis runs, but by about three months ago, it seemed no longer usable -
> > failure after failure.
> > I was using a third-party WFS, and perhaps I could have got round this by
> > adding a WFS provider to the test docker image, but in this plugin's case,
> > I
> > didn't think it worth the significant effort to do so. The WM(T)S tests
> > also
> > use third-party sources and seem stable, so perhaps this wasn't the
> > underlying issue anyway.
> > If an improvement or solution could be found, it would be great to
> > reinstate
> > these tests.
> > Thanks
> > Tom
> > Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> > Sent from:
> > http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
http://www.spatialys.com
More information about the QGIS-Developer mailing list
