[QGIS-Developer] What to do about WFS test failures?
Jonathan Moules
jonathan-lists at lightpear.com
Mon Sep 3 13:54:45 PDT 2018
I'd suggest based on Tom's post that the work should include some sort
of reliable way of testing the WFS client (and of course full test
coverage) - I don't know if GeoServer is Docker-happy these days, but
the default install in a VM should be sufficient for the task (it comes
with test layers) - although GeoServer doesn't support WFS-T for writing.
Cheers,
Jonathan
On 03/09/2018 12:04, Régis Haubourg wrote:
> Hi all,
> I very much think that the WFS client is an really bad state, and is
> not really reliable, especially in WFS-T context.
> The good news is that we just have been funded to refactor it !
> The work should start in september and land in 3.6. I will let our
> dev's come here with more technical details about the goals. I hope we
> will also be able to take benefit of this to this the OGC compliancy
> of the client here.
> Best regards,
> Régis
> Le lun. 3 sept. 2018 à 11:36, Tom Chadwin <tom.chadwin at nnpa.org.uk
> <mailto:tom.chadwin at nnpa.org.uk>> a écrit :
> I can't offer any helpful suggestions, but just to let you know I
> finally had
> to disable all my plugin WFS tests. I used to cope, by rerunning
> failed
> Travis runs, but by about three months ago, it seemed no longer
> usable -
> failure after failure.
> I was using a third-party WFS, and perhaps I could have got round
> this by
> adding a WFS provider to the test docker image, but in this
> plugin's case, I
> didn't think it worth the significant effort to do so. The WM(T)S
> tests also
> use third-party sources and seem stable, so perhaps this wasn't the
> underlying issue anyway.
> If an improvement or solution could be found, it would be great to
> reinstate
> these tests.
> Thanks
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180903/1f2f1530/attachment.html>
