[QGIS-Developer] What to do about WFS test failures?
Andrea Aime
andrea.aime at geo-solutions.it
Tue Sep 4 00:23:28 PDT 2018
On Tue, Sep 4, 2018 at 8:51 AM Jonathan Moules <jonathan-lists at lightpear.com>
wrote:
> I'd suggest based on Tom's post that the work should include some sort of
> reliable way of testing the WFS client (and of course full test coverage) -
> I don't know if GeoServer is Docker-happy these days, but the default
> install in a VM should be sufficient for the task (it comes with test
> layers) - although GeoServer doesn't support WFS-T for writing.
"GeoServer doesn't support WFS-T for writing" ... what??? :-)
The default data directory disables writes for any user but the
administrator, you can change it, or just authenticate
as the admin to run WFS-T
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180904/6e9bf4b9/attachment.html>
