[QGIS-Developer] Debian testing - buster bug
Sebastiaan Couwenberg
sebastic at xs4all.nl
Tue Sep 11 06:59:22 PDT 2018
The underlaying issue is the removal of TLS < 1.2 support by default in
openssl 1.1.1, see: Debian Bug #875423 [0].
TLS 1.0 and/or 1.1 support needs to be enabled explicitly using
SSL_CTX_set_min_proto_version() or SSL_set_min_proto_version() as
mentioned in Message #70 [1].
There is a separate issue for Qt5 which has a workaround in the mean
time. [2]
[0] https://bugs.debian.org/875423
[1] https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=875423#70
[2] https://bugs.debian.org/908567
Kind Regards,
Bas
