[QGIS-Developer] Debian testing - buster bug
Richard Duivenvoorde
rdmailings at duif.net
Tue Sep 11 11:06:30 PDT 2018
On 09/11/2018 03:59 PM, Sebastiaan Couwenberg wrote:
> The underlaying issue is the removal of TLS < 1.2 support by default in
> openssl 1.1.1, see: Debian Bug #875423 [0].
> TLS 1.0 and/or 1.1 support needs to be enabled explicitly using
> SSL_CTX_set_min_proto_version() or SSL_set_min_proto_version() as
> mentioned in Message #70 [1].
> There is a separate issue for Qt5 which has a workaround in the mean
> time. [2]
> [0] https://bugs.debian.org/875423
> [1] https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=875423#70
> [2] https://bugs.debian.org/908567
Mmm, Debian testing user here... :-)
Anything I can do to make (self compiled) QGIS work again? It is now
more or less unusable to me as webservices and plugins are unavailable :(
Can I do anything to fix it in my local version? Do I need to enable
SSL_CTX_set_min_proto_version() or SSL_set_min_proto_version() somewhere?
We do not have power to fix apache on public services, but can I enable
ssl protocol versions on plugins.qgis.org to make that work again?
Any other option?
Regards,
