[QGIS-Developer] Discussing default snapping and node editing settings
Aurelio Pires
anvpires at gmail.com
Wed Sep 12 10:13:23 PDT 2018
Editing the active layer is appropriate, but you may need to snap to
another layer even if it is for reference.
The best would be for the user to be able to tell which layers to use as
a snap.
APires
On 2018-09-12 15:57, Andreas Neumann wrote:
> Hi,
> I noticed that by default QGIS is set to edit ALL layers and also
> snaps to ALL layer by default. I do think that this is a bad default
> setting, esp. with larger projects.
> We had issues because users had WFS layers in their project (read
> only, as reference) and QGIS tries to index these WFS layers and to
> get their vertices in order to snap to them. Then QGIS hangs and
> freezes and there are network time outs. Apparently one has to kill
> QGIS using the task manager.
> I think the better default is to edit and snap only in the active
> layer by default.
> Opinions?
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180912/1504ab88/attachment.html>
