[QGIS-Developer] Discussing default snapping and node editing settings
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Sep 12 10:25:46 PDT 2018
Hi Aurelio,
That's what the advanced digitizing mode is made for, you can define per
layer settings.
Denis
Le mer. 12 sept. 2018 à 13:13, Aurelio Pires <anvpires at gmail.com> a écrit :
> Hi,
> Editing the active layer is appropriate, but you may need to snap to
> another layer even if it is for reference.
> The best would be for the user to be able to tell which layers to use as a
> snap.
> APires
> On 2018-09-12 15:57, Andreas Neumann wrote:
> Hi,
> I noticed that by default QGIS is set to edit ALL layers and also snaps to
> ALL layer by default. I do think that this is a bad default setting, esp.
> with larger projects.
> We had issues because users had WFS layers in their project (read only, as
> reference) and QGIS tries to index these WFS layers and to get their
> vertices in order to snap to them. Then QGIS hangs and freezes and there
> are network time outs. Apparently one has to kill QGIS using the task
> manager.
> I think the better default is to edit and snap only in the active layer by
> default.
> Opinions?
> Andreas
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180912/ecdf65ed/attachment.html>
