[QGIS-Developer] Discussing default snapping and node editing settings
Carlo A. Bertelli (Charta s.r.l.) carlo.bertelli at gmail.com
Wed Sep 12 13:39:56 PDT 2018
If the most frequent case is snapping to the same or to one or two other
layers, is not a good idea to ask the user to resort to advanced settings.
The proposed idea to put the choice of  layers in the basic snapping
options seems a reasonable solution IMHO.
About WFS - but this is true for remote geodatabases with slow connections
- indexing should happen on the current canvas with a clear limit on zoom
level: snapping to at little scale is dangerous, you will never understand
if you snapped to the right now or to something that is hidden behind a
simplification artefact.
A possible solution is viewing an enlarged area about three or four times
the confidence circle and indexing inside it in real time.
c
Il mer 12 set 2018, 19:26 Denis Rouzaud <denis.rouzaud at gmail.com> ha
scritto:
> Hi Aurelio,
> That's what the advanced digitizing mode is made for, you can define per
> layer settings.
> Denis
> Le mer. 12 sept. 2018 à 13:13, Aurelio Pires <anvpires at gmail.com> a
> écrit :
>> Hi,
>> Editing the active layer is appropriate, but you may need to snap to
>> another layer even if it is for reference.
>> The best would be for the user to be able to tell which layers to use as
>> a snap.
>> APires
>> On 2018-09-12 15:57, Andreas Neumann wrote:
>> Hi,
>> I noticed that by default QGIS is set to edit ALL layers and also snaps
>> to ALL layer by default. I do think that this is a bad default setting,
>> esp. with larger projects.
>> We had issues because users had WFS layers in their project (read only,
>> as reference) and QGIS tries to index these WFS layers and to get their
>> vertices in order to snap to them. Then QGIS hangs and freezes and there
>> are network time outs. Apparently one has to kill QGIS using the task
>> manager.
>> I think the better default is to edit and snap only in the active layer
>> by default.
>> Opinions?
>> Andreas
>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Denis Rouzaud
> denis at opengis.ch  <denis at opengis.ch>
> +41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180912/2cdd7861/attachment.html>
More information about the QGIS-Developer mailing list
