[QGIS-Developer] MAC QGIS 3.x build
Denis Rouzaud denis.rouzaud at gmail.com
Thu Sep 13 04:28:52 PDT 2018
Hi Peter,
At this point homebrew-qgisdev tap is not maintained anymore.
The effort is concentrated on osgeo4mac tap, you can use --HEAD to install
current master
see
https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb#L42
I think the most valuable things in the qgis one are the READMEs.
We should move them to the QGIS repo and we could remove homebrew-qgisdev.
I might maybe spend a bit of time cleaning this during the bugfixing.
Denis
Le jeu. 13 sept. 2018 à 04:05, Peter Petrik <
peter.petrik at lutraconsulting.co.uk> a écrit :
> Hi,
> thank you for your suggestions and pointing me the to right places in
> documentations.  After some struggle and frustration, I managed to setup my
> MacOS environment to be able to do some productive work on QGIS. I ended up
> with homebrew approach and especially
> qgis/homebrew-qgisdev/development/README.md was helpful. The QGIS build
> with qt 5.11.1 looks usable too.
> Unfortunately I had some issues with tap qgis/homebrew-qgisdev. It is not
> possible to even tap it from master and qgis3 formulae is not working. The
> QGIS3 formulae in OSGeo4mac homebrew repository is updated and working. I
> am wondering if qgis/homebrew-qgisdev is actively maintained and used?
> Also, what is the benefit to maintain this formula over osgeo4mac/qgis3
> formulae (they are very similar)?
> Prepared https://github.com/qgis/homebrew-qgisdev/pull/72 with changes I
> made to be able to build QGIS3 (I used the scripts, development/README.md
> and followed the QT Creator path in the document). We should update
> qgis/QGIS/INSTALL for OSX (that was the first doc I checked). I am happy to
> help with docs and homebrew-qgisdev, but first I need to clarify the status
> of qgis/homebrew-qgisdev.
> Thanks,
> Peter
> On Tue, Sep 4, 2018 at 3:40 PM David Marteau <dmarteau at 3liz.com> wrote:
>> Le 4 sept. 2018 à 15:12, William Kyngesburye <woklist at kyngchaos.com> a
>> écrit :
>> On Sep 4, 2018, at 4:24 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Tue, 4 Sep 2018 at 19:19, David Marteau <dmarteau at 3liz.com> wrote:
>> Hi Peter,
>> Warning, if you are using macport: qt5.11 is installed by default and you
>> may (or may not)  experience some display problems, instead you may choose
>> to stick to qt5.9 by installing
>> the 'qt59' port
>> Is that the infamous "small canvas" issue?
>> I don't know about that, I use Qt 5.9 in my official build, and it has
>> the small canvas problem.
>> It is more about the "slowness" problem on Mac:
>> https://trac.macports.org/ticket/56915  ,
>> https://issues.qgis.org/issues/19546
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "We are at war with them. Neither in hatred nor revenge and with no
>> particular pleasure I shall kill every ___ I can until the war is over.
>> That is my duty."
>> "Don't you even hate 'em?"
>> "What good would it do if I did? If all the many millions of people of
>> the allied nations devoted an entire year exclusively to hating the ____ it
>> wouldn't kill one ___ nor shorten the war one day."
>> <Ha, ha> "And it might give 'em all stomach ulcers."
>> - Tarzan, on war
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Denis Rouzaud
denis at opengis.ch  <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180913/287204fb/attachment.html>
More information about the QGIS-Developer mailing list
