[QGIS-Developer] MAC QGIS 3.x build
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Sep 13 04:29:36 PDT 2018
But feel free to start moving things !!!
Le jeu. 13 sept. 2018 à 07:28, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi Peter,
> At this point homebrew-qgisdev tap is not maintained anymore.
> The effort is concentrated on osgeo4mac tap, you can use --HEAD to install
> current master
> see
> https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb#L42
> I think the most valuable things in the qgis one are the READMEs.
> We should move them to the QGIS repo and we could remove homebrew-qgisdev.
> I might maybe spend a bit of time cleaning this during the bugfixing.
> Denis
> Le jeu. 13 sept. 2018 à 04:05, Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> a écrit :
>> Hi,
>> thank you for your suggestions and pointing me the to right places in
>> documentations. After some struggle and frustration, I managed to setup my
>> MacOS environment to be able to do some productive work on QGIS. I ended up
>> with homebrew approach and especially
>> qgis/homebrew-qgisdev/development/README.md was helpful. The QGIS build
>> with qt 5.11.1 looks usable too.
>> Unfortunately I had some issues with tap qgis/homebrew-qgisdev. It is not
>> possible to even tap it from master and qgis3 formulae is not working. The
>> QGIS3 formulae in OSGeo4mac homebrew repository is updated and working. I
>> am wondering if qgis/homebrew-qgisdev is actively maintained and used?
>> Also, what is the benefit to maintain this formula over osgeo4mac/qgis3
>> formulae (they are very similar)?
>> Prepared https://github.com/qgis/homebrew-qgisdev/pull/72 with changes I
>> made to be able to build QGIS3 (I used the scripts, development/README.md
>> and followed the QT Creator path in the document). We should update
>> qgis/QGIS/INSTALL for OSX (that was the first doc I checked). I am happy to
>> help with docs and homebrew-qgisdev, but first I need to clarify the status
>> of qgis/homebrew-qgisdev.
>> Thanks,
>> Peter
>> On Tue, Sep 4, 2018 at 3:40 PM David Marteau <dmarteau at 3liz.com> wrote:
>>> Le 4 sept. 2018 à 15:12, William Kyngesburye <woklist at kyngchaos.com> a
>>> écrit :
>>> On Sep 4, 2018, at 4:24 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> On Tue, 4 Sep 2018 at 19:19, David Marteau <dmarteau at 3liz.com> wrote:
>>> Hi Peter,
>>> Warning, if you are using macport: qt5.11 is installed by default and
>>> you may (or may not) experience some display problems, instead you may
>>> choose to stick to qt5.9 by installing
>>> the 'qt59' port
>>> Is that the infamous "small canvas" issue?
>>> I don't know about that, I use Qt 5.9 in my official build, and it has
>>> the small canvas problem.
>>> It is more about the "slowness" problem on Mac:
>>> https://trac.macports.org/ticket/56915 ,
>>> https://issues.qgis.org/issues/19546
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "We are at war with them. Neither in hatred nor revenge and with no
>>> particular pleasure I shall kill every ___ I can until the war is over.
>>> That is my duty."
>>> "Don't you even hate 'em?"
>>> "What good would it do if I did? If all the many millions of people of
>>> the allied nations devoted an entire year exclusively to hating the ____ it
>>> wouldn't kill one ___ nor shorten the war one day."
>>> <Ha, ha> "And it might give 'em all stomach ulcers."
>>> - Tarzan, on war
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Denis Rouzaud
> denis at opengis.ch <denis at opengis.ch>
> +41 76 370 21 22
Denis Rouzaud
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180913/0fe7713b/attachment-0001.html>
