[QGIS-Developer] MAC QGIS 3.x build
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Thu Sep 13 04:34:22 PDT 2018
sounds good, +1 for moving READMEs to qgis/QGIS and removal/deprecation of
homebrew-qgisdev.
I do not have that much experience yet with development on the platform to
write full docs, but I can help with review/test of the new docs once
ported.
In the meantime, could someone with merge rights in homebrew-qgisdev just
add big note at the beginning that this is not maintained anymore and
osgeo4mac should be used instead?
thanks
P.
On Thu, Sep 13, 2018 at 1:29 PM Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> But feel free to start moving things !!!
> Le jeu. 13 sept. 2018 à 07:28, Denis Rouzaud <denis.rouzaud at gmail.com> a
> écrit :
>> Hi Peter,
>> At this point homebrew-qgisdev tap is not maintained anymore.
>> The effort is concentrated on osgeo4mac tap, you can use --HEAD to
>> install current master
>> see
>> https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb#L42
>> I think the most valuable things in the qgis one are the READMEs.
>> We should move them to the QGIS repo and we could remove homebrew-qgisdev.
>> I might maybe spend a bit of time cleaning this during the bugfixing.
>> Denis
>> Le jeu. 13 sept. 2018 à 04:05, Peter Petrik <
>> peter.petrik at lutraconsulting.co.uk> a écrit :
>>> Hi,
>>> thank you for your suggestions and pointing me the to right places in
>>> documentations. After some struggle and frustration, I managed to setup my
>>> MacOS environment to be able to do some productive work on QGIS. I ended up
>>> with homebrew approach and especially
>>> qgis/homebrew-qgisdev/development/README.md was helpful. The QGIS build
>>> with qt 5.11.1 looks usable too.
>>> Unfortunately I had some issues with tap qgis/homebrew-qgisdev. It is
>>> not possible to even tap it from master and qgis3 formulae is not working.
>>> The QGIS3 formulae in OSGeo4mac homebrew repository is updated and working.
>>> I am wondering if qgis/homebrew-qgisdev is actively maintained and used?
>>> Also, what is the benefit to maintain this formula over osgeo4mac/qgis3
>>> formulae (they are very similar)?
>>> Prepared https://github.com/qgis/homebrew-qgisdev/pull/72 with changes
>>> I made to be able to build QGIS3 (I used the scripts, development/README.md
>>> and followed the QT Creator path in the document). We should update
>>> qgis/QGIS/INSTALL for OSX (that was the first doc I checked). I am happy to
>>> help with docs and homebrew-qgisdev, but first I need to clarify the status
>>> of qgis/homebrew-qgisdev.
>>> Thanks,
>>> Peter
>>> On Tue, Sep 4, 2018 at 3:40 PM David Marteau <dmarteau at 3liz.com> wrote:
>>>> Le 4 sept. 2018 à 15:12, William Kyngesburye <woklist at kyngchaos.com> a
>>>> écrit :
>>>> On Sep 4, 2018, at 4:24 AM, Nyall Dawson <nyall.dawson at gmail.com>
>>>> wrote:
>>>> On Tue, 4 Sep 2018 at 19:19, David Marteau <dmarteau at 3liz.com> wrote:
>>>> Hi Peter,
>>>> Warning, if you are using macport: qt5.11 is installed by default and
>>>> you may (or may not) experience some display problems, instead you may
>>>> choose to stick to qt5.9 by installing
>>>> the 'qt59' port
>>>> Is that the infamous "small canvas" issue?
>>>> I don't know about that, I use Qt 5.9 in my official build, and it has
>>>> the small canvas problem.
>>>> It is more about the "slowness" problem on Mac:
>>>> https://trac.macports.org/ticket/56915 ,
>>>> https://issues.qgis.org/issues/19546
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "We are at war with them. Neither in hatred nor revenge and with no
>>>> particular pleasure I shall kill every ___ I can until the war is over.
>>>> That is my duty."
>>>> "Don't you even hate 'em?"
>>>> "What good would it do if I did? If all the many millions of people of
>>>> the allied nations devoted an entire year exclusively to hating the ____ it
>>>> wouldn't kill one ___ nor shorten the war one day."
>>>> <Ha, ha> "And it might give 'em all stomach ulcers."
>>>> - Tarzan, on war
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Denis Rouzaud
>> denis at opengis.ch <denis at opengis.ch>
>> +41 76 370 21 22
> Denis Rouzaud
> +41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180913/7b389a5a/attachment.html>
