[QGIS-Developer] MAC QGIS 3.x build
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Sep 13 04:54:16 PDT 2018
Tim,
Can you grant one of with admin rights (not only commit rights) on
homebrew-qgisdev ?
Cheers,
Denis
Le jeu. 13 sept. 2018 à 07:34, Peter Petrik <
peter.petrik at lutraconsulting.co.uk> a écrit :
> sounds good, +1 for moving READMEs to qgis/QGIS and removal/deprecation of
> homebrew-qgisdev.
> I do not have that much experience yet with development on the platform to
> write full docs, but I can help with review/test of the new docs once
> ported.
> In the meantime, could someone with merge rights in homebrew-qgisdev just
> add big note at the beginning that this is not maintained anymore and
> osgeo4mac should be used instead?
> thanks
> P.
> On Thu, Sep 13, 2018 at 1:29 PM Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
>> But feel free to start moving things !!!
>> Le jeu. 13 sept. 2018 à 07:28, Denis Rouzaud <denis.rouzaud at gmail.com> a
>> écrit :
>>> Hi Peter,
>>> At this point homebrew-qgisdev tap is not maintained anymore.
>>> The effort is concentrated on osgeo4mac tap, you can use --HEAD to
>>> install current master
>>> see
>>> https://github.com/OSGeo/homebrew-osgeo4mac/blob/master/Formula/qgis3.rb#L42
>>> I think the most valuable things in the qgis one are the READMEs.
>>> We should move them to the QGIS repo and we could remove
>>> homebrew-qgisdev.
>>> I might maybe spend a bit of time cleaning this during the bugfixing.
>>> Denis
>>> Le jeu. 13 sept. 2018 à 04:05, Peter Petrik <
>>>> Hi,
>>>> thank you for your suggestions and pointing me the to right places in
>>>> documentations. After some struggle and frustration, I managed to setup my
>>>> MacOS environment to be able to do some productive work on QGIS. I ended up
>>>> with homebrew approach and especially
>>>> qgis/homebrew-qgisdev/development/README.md was helpful. The QGIS build
>>>> with qt 5.11.1 looks usable too.
>>>> Unfortunately I had some issues with tap qgis/homebrew-qgisdev. It is
>>>> not possible to even tap it from master and qgis3 formulae is not working.
>>>> The QGIS3 formulae in OSGeo4mac homebrew repository is updated and working.
>>>> I am wondering if qgis/homebrew-qgisdev is actively maintained and used?
>>>> Also, what is the benefit to maintain this formula over osgeo4mac/qgis3
>>>> formulae (they are very similar)?
>>>> Prepared https://github.com/qgis/homebrew-qgisdev/pull/72 with changes
>>>> I made to be able to build QGIS3 (I used the scripts, development/README.md
>>>> and followed the QT Creator path in the document). We should update
>>>> qgis/QGIS/INSTALL for OSX (that was the first doc I checked). I am happy to
>>>> help with docs and homebrew-qgisdev, but first I need to clarify the status
>>>> of qgis/homebrew-qgisdev.
>>>> Thanks,
>>>> Peter
>>>> On Tue, Sep 4, 2018 at 3:40 PM David Marteau <dmarteau at 3liz.com> wrote:
>>>>> Le 4 sept. 2018 à 15:12, William Kyngesburye <woklist at kyngchaos.com>
>>>>> a écrit :
>>>>> On Sep 4, 2018, at 4:24 AM, Nyall Dawson <nyall.dawson at gmail.com>
>>>>> wrote:
>>>>> On Tue, 4 Sep 2018 at 19:19, David Marteau <dmarteau at 3liz.com> wrote:
>>>>> Hi Peter,
>>>>> Warning, if you are using macport: qt5.11 is installed by default and
>>>>> you may (or may not) experience some display problems, instead you may
>>>>> choose to stick to qt5.9 by installing
>>>>> the 'qt59' port
>>>>> Is that the infamous "small canvas" issue?
>>>>> I don't know about that, I use Qt 5.9 in my official build, and it has
>>>>> the small canvas problem.
>>>>> It is more about the "slowness" problem on Mac:
>>>>> https://trac.macports.org/ticket/56915 ,
>>>>> https://issues.qgis.org/issues/19546
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "We are at war with them. Neither in hatred nor revenge and with no
>>>>> particular pleasure I shall kill every ___ I can until the war is over.
>>>>> That is my duty."
>>>>> "Don't you even hate 'em?"
>>>>> "What good would it do if I did? If all the many millions of people of
>>>>> the allied nations devoted an entire year exclusively to hating the ____ it
>>>>> wouldn't kill one ___ nor shorten the war one day."
>>>>> <Ha, ha> "And it might give 'em all stomach ulcers."
>>>>> - Tarzan, on war
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Denis Rouzaud
>>> denis at opengis.ch <denis at opengis.ch>
>>> +41 76 370 21 22
>> Denis Rouzaud
>> +41 76 370 21 22
Denis Rouzaud
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180913/dfee5305/attachment.html>
