[QGIS-Developer] qgis2web and qtwebkit?
Tom Chadwin
tom.chadwin at nnpa.org.uk
Mon Sep 17 01:24:10 PDT 2018
Hello all
Sebastiaan Couwenberg wrote
> The proper solution is to port the plugin to QtWebEngine with Qt5.
> That's what Qt upstream recommends over QtWebKit.
The QtWebkit issue has caused problems with qgis2web many times:
https://github.com/tomchadwin/qgis2web/issues?utf8=%E2%9C%93&q=is%3Aissue+qtwebkit+
I've never done any work toward removing QtWebkit from qgis2web, for three
main reasons:
- as a Windows user, I don't fully understand the underlying issues (eg is
it QtWebkit itself or its Python bindings?)
- my belief was that QGIS itself depended on QtWebkit (possibly for HTML
support in labels or some such)
- QtWebEngine has lagged behind QtWebkit in functionality (I don't know if
that is still the case)
I guess my questions arising are:
- is the problem only with Qt4, and hence QGIS 2? If so, with 3.4 becoming
LTR next spring, my strong inclination is not to bother attempting to
migrate to WebEngine
- does QGIS core still use Webkit?
- are there any other reasons that migrating from Webkit is required under
Qt5?
Thanks for any pointers
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
