[QGIS-Developer] QGIS Server QGIS_PROJECT_FILE ignoring MAP parameter?
Adam Borczyk
adam.borczyk at gis-support.pl
Thu Sep 20 05:22:39 PDT 2018
Forgot my config if it matters:
- Ubuntu server 18.04
- QGIS Server 2.18
- Apache 2.4.29 (config: https://pastebin.com/QnTc19Gj )
On Thu, 20 Sep 2018 at 14:19, Adam Borczyk <adam.borczyk at gis-support.pl>
wrote:
> Hi everyone,
> is it expected behaviour for QGIS Server 2.18 to ignore MAP parameter in
> URL when QGIS_PROJECT_FILE environment variable is set?
> I have QGIS_PROJECT_FILE set, so my endpoint "/wms" serves default
> project, but I'd like to access another project from the same endpoint -
> I'm trying here with just specifying MAP parameter, but changing it's value
> does not affect response in any way. In fact, I can do "&MAP=asdfasdf" and
> still get default project, while changing other parameters works normally.
> I though Environment Variable works as default option that you can
> override, but it seems it doesn't?
> Best regards
> Adam Borczyk
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180920/b76d97eb/attachment.html>
