[QGIS-Developer] Has QgsLayout.itemById() changed?
Raymond Nijssen r.nijssen at terglobo.nl
Fri Sep 21 06:47:20 PDT 2018
Will do so. Thank you Alessandro!
On 21-09-18 15:32, Alessandro Pasotti wrote:
> Hi Raymond,
> confirmed, there is probably something broken in the bindings, please
> file a ticket.
> On Fri, Sep 21, 2018 at 3:20 PM Raymond Nijssen <r.nijssen at terglobo.nl
> <mailto:r.nijssen at terglobo.nl>> wrote:
>     Running this python script (in qgis 3.3):
>     p = QgsProject.instance()
>     lom = p.layoutManager()
>     lo = lom.layoutByName('a4')
>     item = lo.itemById('label_title')
>     print(item)
>     a few weeks ago, it outputed this:
>     <qgis._core.QgsLayoutItemLabel object at 0x7fe90b6d0318>
>     but today it outputs:
>     <qgis._core.QgsLayoutItem object at 0x7fe90b6d0318>
>     My next line is:
>     item.setText('hello')
>     which doesn't work anymore, because there is no setText() function on a
>     QgsLayoutItem. Has anything changed recently? Does any one know a
>     solution?
>     Regards,
>     Raymond
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
The Netherlands
+31 (0) 6 25 31 49 83
More information about the QGIS-Developer mailing list
