[QGIS-Developer] Has QgsLayout.itemById() changed?
Alessandro Pasotti
apasotti at gmail.com
Fri Sep 21 07:29:58 PDT 2018
Hi Raymond,
You know what? I've just rebased and rebuilt current master and I cannot
reproduce it anymore :(
I checked the bindings code and it looks fine, can you check latest master?
On Fri, Sep 21, 2018 at 3:47 PM Raymond Nijssen <r.nijssen at terglobo.nl>
wrote:
> Will do so. Thank you Alessandro!
> On 21-09-18 15:32, Alessandro Pasotti wrote:
> > Hi Raymond,
> > confirmed, there is probably something broken in the bindings, please
> > file a ticket.
> > On Fri, Sep 21, 2018 at 3:20 PM Raymond Nijssen <r.nijssen at terglobo.nl
> > <mailto:r.nijssen at terglobo.nl>> wrote:
> > Running this python script (in qgis 3.3):
> > p = QgsProject.instance()
> > lom = p.layoutManager()
> > lo = lom.layoutByName('a4')
> > item = lo.itemById('label_title')
> > print(item)
> > a few weeks ago, it outputed this:
> > <qgis._core.QgsLayoutItemLabel object at 0x7fe90b6d0318>
> > but today it outputs:
> > <qgis._core.QgsLayoutItem object at 0x7fe90b6d0318>
> > My next line is:
> > item.setText('hello')
> > which doesn't work anymore, because there is no setText() function
> on a
> > QgsLayoutItem. Has anything changed recently? Does any one know a
> > solution?
> > Regards,
> > Raymond
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:
> QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Alessandro Pasotti
> > w3: www.itopen.it <http://www.itopen.it>
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> The Netherlands
> +31 (0) 6 25 31 49 83
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180921/7b1cb90e/attachment.html>
