[QGIS-Developer] plugins?
Richard Duivenvoorde rdmailings at duif.net
Sat Sep 22 04:04:21 PDT 2018
On 09/22/2018 08:03 AM, Arne Linløkken wrote:
> I wonder why there are so few plugins installed with the 2.18.24 version
> of QGIS. Where is Congedo’s SCP?
Plugins are to be installed by yourself via the Plugin Manager.
You should see the 'SCP' plugin there and install it.
There is also an online list of plugins:
http://plugins.qgis.org/plugins/
where you can search there too? Installing should be doen vai QGIS though.
Searching for scp I find:
http://plugins.qgis.org/plugins/scpplugin/
IF it does not show up in your list in QGIS, then apparently QGIS cannot
load the plugins.xml? Maybe you are behind a proxy (which you can give
in the network properties?)
Regards,
More information about the QGIS-Developer mailing list
