[QGIS-Developer] plugins?
Arne Linløkken arne.linlokken at inn.no
Sat Sep 22 06:16:48 PDT 2018
I just downloaded QGis 3.2.3-Bonn, andthere  SCP plugin was included. Now I struggle with the "Clip multiple raster" function. I can't get hold of the input files by clicking on the [cid:image003.jpg at 01D45287.47B00E90]  though both raster and shape files are added. Earlier versions showed the selected raster, and the shape file name appeared at once when marking in “Use vector for….”. Is there a bug or am I doing something wrong. So far I haven’t found an answer in the SCP manual.
Arne
[cid:image004.jpg at 01D45287.47B00E90]
-----Opprinnelig melding-----
Fra: Borys Jurgiel <info at borysjurgiel.pl>
Sendt: lørdag 22. september 2018 14:16
Til: qgis-developer at lists.osgeo.org; richard at duif.net
Kopi: Arne Linløkken <arne.linlokken at inn.no>
Emne: Re: [QGIS-Developer] plugins?
Dnia sobota, 22 września 2018 13:04:21 CEST Richard Duivenvoorde pisze:
> Searching for scp I find:
> http://plugins.qgis.org/plugins/scpplugin/
Just to clarify, Arne meant that one:
http://plugins.qgis.org/plugins/SemiAutomaticClassificationPlugin/
As Richard said, if your QGIS can access the network, you should see ~800 available plugins in the Plugins -> Manage and Install Plugins menu.
Regards,
Borys
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/1f9f31b4/attachment-0001.html>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/1f9f31b4/attachment-0002.jpg>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/1f9f31b4/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
