[QGIS-Developer] plugins?
Jorge Gustavo Rocha
jgr at di.uminho.pt
Sat Sep 22 07:30:09 PDT 2018
Hi Arne,
Please use the SCP issue tracker to report your problem:
https://github.com/semiautomaticgit/SemiAutomaticClassificationPlugin/issues
Please report your QGIS version (QGis 3.2.3-Bonn, as you said) and SCP
version (go to SCP → ABout, SCP version, like 6.2.3).
Add a description of the steps you take before trying "Clip multiple
rasters".
Regards,
Jorge
Às 14:16 de 22/09/2018, Arne Linløkken escreveu:
> I just downloaded QGis 3.2.3-Bonn, andthere SCP plugin was included.
> Now I struggle with the "Clip multiple raster" function. I can't get
> hold of the input files by clicking on the though both raster and shape
> files are added. Earlier versions showed the selected raster, and the
> shape file name appeared at once when marking in “Use vector for….”. Is
> there a bug or am I doing something wrong. So far I haven’t found an
> answer in the SCP manual.
> Arne
> -----Opprinnelig melding-----
> Fra: Borys Jurgiel <info at borysjurgiel.pl>
> Sendt: lørdag 22. september 2018 14:16
> Til: qgis-developer at lists.osgeo.org; richard at duif.net
> Kopi: Arne Linløkken <arne.linlokken at inn.no>
> Emne: Re: [QGIS-Developer] plugins?
> Dnia sobota, 22 września 2018 13:04:21 CEST Richard Duivenvoorde pisze:
>> Searching for scp I find:
>> http://plugins.qgis.org/plugins/scpplugin/
> Just to clarify, Arne meant that one:
> http://plugins.qgis.org/plugins/SemiAutomaticClassificationPlugin/
> As Richard said, if your QGIS can access the network, you should see
> ~800 available plugins in the Plugins -> Manage and Install Plugins menu.
> Regards,
> Borys
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
