[QGIS-Developer] plugins?
Lene Fischer lfi at ign.ku.dk
Sat Sep 22 12:31:21 PDT 2018
You can set the band tab set to add the multiple layers
Then select the band set and click run.
Lene Fischer
Associate Professor
University of Copenhagen
Department of Geoscience and Natural Resource Management
Forest and Landscape College
Nødebovej 77a
3480 Fredensborg
Denmark
MOB +45 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[cid:image001.gif at 01D452BB.9A7CF730]
[cid:image002.png at 01D452BB.9A7CF730]<@Lene_Fischer>
Fra: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne af Arne Linløkken
Sendt: 22. september 2018 15:17
Til: Borys Jurgiel; qgis-developer at lists.osgeo.org; richard at duif.net
Emne: Re: [QGIS-Developer] plugins?
I just downloaded QGis 3.2.3-Bonn, andthere  SCP plugin was included. Now I struggle with the "Clip multiple raster" function. I can't get hold of the input files by clicking on the [cid:image003.jpg at 01D452BB.9A7CF730]  though both raster and shape files are added. Earlier versions showed the selected raster, and the shape file name appeared at once when marking in “Use vector for….”. Is there a bug or am I doing something wrong. So far I haven’t found an answer in the SCP manual.
Arne
[cid:image004.jpg at 01D452BB.9A7CF730]
-----Opprinnelig melding-----
Fra: Borys Jurgiel <info at borysjurgiel.pl>
Sendt: lørdag 22. september 2018 14:16
Til: qgis-developer at lists.osgeo.org; richard at duif.net
Kopi: Arne Linløkken <arne.linlokken at inn.no>
Dnia sobota, 22 września 2018 13:04:21 CEST Richard Duivenvoorde pisze:
> Searching for scp I find:
> http://plugins.qgis.org/plugins/scpplugin/
Just to clarify, Arne meant that one:
http://plugins.qgis.org/plugins/SemiAutomaticClassificationPlugin/
As Richard said, if your QGIS can access the network, you should see ~800 available plugins in the Plugins -> Manage and Install Plugins menu.
Regards,
Borys
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/14ea4cca/attachment-0001.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/14ea4cca/attachment-0001.gif>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/14ea4cca/attachment-0001.png>
Type: image/jpeg
Desc: image003.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/14ea4cca/attachment-0002.jpg>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180922/14ea4cca/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
