[QGIS-Developer] Python API for 3D
Nyall Dawson
nyall.dawson at gmail.com
Sat Sep 29 23:51:24 PDT 2018
On Sat, 29 Sep 2018 at 09:36, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Sat, 29 Sep 2018 at 00:21, Martin Dobias <wonder.sk at gmail.com> wrote:
> > I think for the time being we should still treat the 3D library as
> > having unstable API - so I wanted to check how others would feel about
> > having Python API for qgis_3d that would be marked as unstable, i.e.
> > there may be changes between 3.x releases? I think with big warnings
> > in the docs that the API may change we can get others to experiment
> > with 3D functionality while not offending anyone too much if we break
> > it later. The idea is that the API would get frozen at some point
> > later in 3.x release cycle or for QGIS 4.
> I don't see an issue with this -- there's other parts of code exposed
> to PyQGIS which is also clearly marked as non-stable. Some processing
> classes for instance.
Note this touches on discussion at
https://github.com/qgis/QGIS/pull/8054 too. Quoting:
"Maybe we should do qt approach and have "technology preview" classes,
before classes mature? We could even do this as a general rule - new
classes are tech previews for 2 minor releases."
Nyall
