[QGIS-Developer] Python API for 3D
Nyall Dawson
nyall.dawson at gmail.com
Fri Sep 28 16:36:30 PDT 2018
On Sat, 29 Sep 2018 at 00:21, Martin Dobias <wonder.sk at gmail.com> wrote:
> I think for the time being we should still treat the 3D library as
> having unstable API - so I wanted to check how others would feel about
> having Python API for qgis_3d that would be marked as unstable, i.e.
> there may be changes between 3.x releases? I think with big warnings
> in the docs that the API may change we can get others to experiment
> with 3D functionality while not offending anyone too much if we break
> it later. The idea is that the API would get frozen at some point
> later in 3.x release cycle or for QGIS 4.
I don't see an issue with this -- there's other parts of code exposed
to PyQGIS which is also clearly marked as non-stable. Some processing
classes for instance.
Nyall
