[QGIS-Developer] Python API for 3D
Martin Dobias
wonder.sk at gmail.com
Fri Sep 28 08:09:57 PDT 2018
Hi Matthias
On Fri, Sep 28, 2018 at 4:47 PM Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Martin,
> I think that's a good move. Having an experimental Python 3D API is better
> than not having a Python 3D API. And if it's communicated clearly, it's
> every developers choice to build something on top of an unstable API.
> Just to ask, do you have clear plans for API changes or is it more a move
> to keep the door for API modifications open in case it turns out it is
> required?
I don't really have any concrete plans for API changes within the 3D
library - I just feel that it may easily happen in the future as we will be
adding more functionality or refactoring existing code :-)
Anyway I would try to keep the changes in API break docs so that devs have
some guidance in case there are some breaks.
Cheers
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180928/3ea40862/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180928/3ea40862/attachment.png>
