[QGIS-Developer] Python API for 3D
Alessandro Pasotti apasotti at gmail.com
Fri Sep 28 07:24:19 PDT 2018
On Fri, Sep 28, 2018 at 4:21 PM Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi all
> I have been thinking it would be good to finally have Python API also
> for qgis_3d library. Until now I have kept the 3D library
> intentionally without Python bindings so that it is possible to move
> the code around without being blocked by the API stability
> requirement.
> I think for the time being we should still treat the 3D library as
> having unstable API - so I wanted to check how others would feel about
> having Python API for qgis_3d that would be marked as unstable, i.e.
> there may be changes between 3.x releases? I think with big warnings
> in the docs that the API may change we can get others to experiment
> with 3D functionality while not offending anyone too much if we break
> it later. The idea is that the API would get frozen at some point
> later in 3.x release cycle or for QGIS 4.
> Cheers
> Martin
Hi Martin,
I think it's a good idea!
... if the warning is big enough and not light gray over a white background
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180928/89f8a5bb/attachment.html>
More information about the QGIS-Developer mailing list
