[QGIS-Developer] GSoC 2019 for QGIS 3D Improvement Proposal
Andreas Neumann a.neumann at carto.net
Mon Apr 1 04:30:45 PDT 2019
Hi Ismail,
Looks nice - thanks for the proposal. Hopefully it will be accepted!
I'd love to see all of these improvements, esp. the billboard ones -
because currently there is no way to properly label something in 3d.
I added a suggestion for the billboards: Allow leader lines between the
original point feature and the billboard location above the point
feature, with a configurable vertical offset (best also data-defined).
It would help better locate the position of the actual feature that is
labeled.
There are two other ideas regarding QGIS 3D:
 	* allow highlighting of objects in 3D when using the Identify tool.
Currently one can pick an object in 3d and query the attributes, but
there is no visual feedback what object was actually selected. perhaps
with the new line rendering that Martin is currently working on, this
could be used to draw a red 3d outline of the object picked?
 	* allow a per layer (or per category) wireframe mode for 3d polygons
and terrain (in order to be able to look through the terrain or 3d
objects).
I understand that this would be too much for the GSOC proposal, but
nevertheless I would like to mention those here, as I think they are
important. I totally understand, of course, that they are too much for
the GSOC proposal.
Thanks and good luck,
Andreas
On 2019-04-01 12:28, Ismail Sunni wrote:
> Dear QGIS developers,
> My name is Ismail Sunni, I am from Indonesia. Currently, I am studying in Germany for my master degree. Since I am now a student, I want to participate in this year Google Summer of Code for QGIS. I am interested to contribute and work on the 3D improvement [1]. It's still young and I think that I can help with making it more complete.
> I have discussed with Martin Dobias for a more detail idea and start my proposal. Now, my proposal is more or less ready (according to me). But it would be better if I get some feedback or suggestions from the QGIS community itself. Since it will give impact to the community.
> If you are interested, you can check my proposal in this URL: https://docs.google.com/document/d/1RcXiEyziQyGurqDGRBN3g-het33liVD81WFjv8qQlt8/edit?usp=sharing
> Please don't be hesitate to make a comment either in this email thread or even in the document itself.
> Thank you
> Best regards
> Ismail Sunni
> ismailsunni.wordpress.com [2]
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Links:
[1]
https://github.com/qgis/QGIS/wiki/Google-Summer-of-Code-2019-Ideas#qgis-3d-improvements
[2] http://ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190401/de183b4d/attachment.html>
More information about the QGIS-Developer mailing list
