[QGIS-Developer] GSoC 2019 for QGIS 3D Improvement Proposal
SIGéal sigeal at sigeal.com
Tue Apr 2 02:22:36 PDT 2019
I also had some similar issues while testing the 3D window on W10 with
QGIS 3.6.1 :
- sometimes, the 3D window loses its controls (no title bar, no status
bar), but I get them back if I resize the window with the mouse (on
click release)
- the 3D window appears in View -> Panels menu, but not in the
contextual menu (right click in the empty toolbar zone)
- if I uncheck the 3D window in the View -> Panels menu, it is closed
and I can't get it back
- I had crashes while trying to dock a new 3D window in an existing one
(which normally create a new tab)
- it would be great to be able to minimize 3D windows
Kind regards,
Christophe
Le 02/04/2019 à 10:53, Ismail Sunni a écrit :
> Hi Tim,
>     Nice proposal Sunni! On the Mac the 3d window is a bit of a pain
>     because it is a dock window so cannot be maximised easily and when
>     you do resize it it tends to dock into the main window so it
>     always makes it a bit clunky in demos. It would be really nice if
>     it either replaced the main 2d map canvas or was possible to use
>     it as a normal window instead of a dock widget so you can easily
>     maximise it.
> Ah really? I can't remember get that issue in Mac before.
> (un)fortunately, I am not using Mac anymore, so I am not sure if can
> help with that. Perhaps Peter can check it :)
>     Oh and then please implement some kind of star wars tie-fighter vs
>     x-wind chase through my neighbourhood game as an Easter egg in it :-)
> Haha, nice idea! Let me check if I prefer star wars or Avengers :D
> Thanks also for your comment in the Google Docs.
> Best Regards
> On Mon, Apr 1, 2019 at 4:25 PM Tim Sutton <tim at kartoza.com
>     maximise it.
>     Regards
>     Tim
>>     On 01 Apr 2019, at 14:26, Ismail Sunni <imajimatika at gmail.com
>>     <mailto:imajimatika at gmail.com>> wrote:
>>     HI Mathieu
>>         Regarding on-screen navigation, it'd be good to think of an
>>         implementation that would work for both 2D as well as 3D map
>>         canvases when conceptualizing the way ahead (I'm not
>>         suggesting you implement this as part of this GSoC plan, just
>>         seeding the idea as it might shape way you move forward).
>>         It'd be useful in a few places across QGIS to have some ultra
>>         basic zooming and panning controls attached to a qgsmapcanvas.
>>     Hmm, yeah, I will think about it in the design. I agree, if it
>>     can be used on other part, it will be better for sure.
>>      Hi Nyall,
>>         Great proposal Ismail -- all these features would be lovely
>>         to see!
>>         Reading over the billboard proposal, I'd strongly suggest
>>         that you
>>         re-use QGIS marker symbology here to render the actual billboard
>>         content. Amongst other benefits, this would allow re-use of
>>         identical
>>         symbols between 2d and 3d maps.
>>         Best of luck with the coding!
>>     As Martin said, it's a good point. I will be happy to re-use
>>     existing code, I think it's a win-win solution.
>>     Thanks, Nyall
>>     Hi Andreas
>>         Hi Ismail,
>>         Looks nice - thanks for the proposal. Hopefully it will be
>>         accepted!
>>         I'd love to see all of these improvements, esp. the billboard
>>         ones - because currently there is no way to properly label
>>         something in 3d.
>>         I added a suggestion for the billboards: Allow leader lines
>>         between the original point feature and the billboard location
>>         above the point feature, with a configurable vertical offset
>>         (best also data-defined). It would help better locate the
>>         position of the actual feature that is labeled.
>>         There are two other ideas regarding QGIS 3D:
>>           * allow highlighting of objects in 3D when using the
>>             Identify tool. Currently one can pick an object in 3d and
>>             query the attributes, but there is no visual feedback
>>             what object was actually selected. perhaps with the new
>>             line rendering that Martin is currently working on, this
>>             could be used to draw a red 3d outline of the object picked?
>>           * allow a per layer (or per category) wireframe mode for 3d
>>             polygons and terrain (in order to be able to look through
>>             the terrain or 3d objects).
>>         I understand that this would be too much for the GSOC
>>         proposal, but nevertheless I would like to mention those
>>         here, as I think they are important. I totally understand, of
>>         course, that they are too much for the GSOC proposal.
>>         Thanks and good luck,
>>         Andreas
>>     Yeah, regarding the billboard, that's one of the common use cases
>>     that Martin and I discussed. So it's under my radar to have
>>     something like that in the implementation. Btw, thanks for your
>>     comments in the Google Doc.
>>     Those two ideas are interesting and should be implemented somehow
>>     in the future. But as you said, perhaps it's too much for the
>>     GSoC proposal :). I can't promise, but who knows what will happen
>>     in the future :)
>>         I can only add that I am also happy that Ismail would like to
>>         participate in GSoC and I hope this proposal will get
>>         accepted because
>>         the proposal looks great.
>>     Thanks for your help and guidance, Martin :)
>>     Best regards
>>     On Mon, Apr 1, 2019 at 2:39 PM Martin Dobias <wonder.sk at gmail.com
>>     <mailto:wonder.sk at gmail.com>> wrote:
>>         Hi
>>         On Mon, Apr 1, 2019 at 1:11 PM Nyall Dawson
>>         <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> wrote:
>>         > On Mon, 1 Apr 2019 at 20:28, Ismail Sunni
>>         <imajimatika at gmail.com <mailto:imajimatika at gmail.com>> wrote:
>>         > > Dear QGIS developers,
>>         > > My name is Ismail Sunni, I am from Indonesia. Currently,
>>         I am studying in Germany for my master degree. Since I am now
>>         a student, I want to participate in this year Google Summer
>>         of Code for QGIS. I am interested to contribute and work on
>>         the 3D improvement. It's still young and I think that I can
>>         help with making it more complete.
>>         > > I have discussed with Martin Dobias for a more detail
>>         idea and start my proposal. Now, my proposal is more or less
>>         ready (according to me). But it would be better if I get some
>>         feedback or suggestions from the QGIS community itself. Since
>>         it will give impact to the community.
>>         > > If you are interested, you can check my proposal in this
>>         URL:https://docs.google.com/document/d/1RcXiEyziQyGurqDGRBN3g-het33liVD81WFjv8qQlt8/edit?usp=sharing
>>         > > Please don't be hesitate to make a comment either in this
>>         email thread or even in the document itself.
>>         accepted because
>>         that you
>>         billboard
>>         identical
>>         That's a good point!
>>         Cheers
>>         Martin
>>     Ismail Sunni
>>     ismailsunni.wordpress.com <http://ismailsunni.wordpress.com/>
>>     _______________________________________________
>>     QGIS-Developer mailing list
>>     QGIS-Developer at lists.osgeo.org
>>     <mailto:QGIS-Developer at lists.osgeo.org>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     *Tim Sutton*
>     *Co-founder:*Kartoza
>     *Ex Project chair:*QGIS.org <http://QGIS.org>
>     Visit http://kartoza.com <http://kartoza.com/> to find out about
>     open source:
>     Desktop GIS programming services
>     Geospatial web development
>     GIS Training
>     Consulting Services
>     *Skype*: timlinux
>     *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
>     I'd love to connect. Here's my calendar link
>     <https://calendly.com/timlinux> to make finding time easy.
> Ismail Sunni
> ismailsunni.wordpress.com <http://ismailsunni.wordpress.com>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190402/3cf88052/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190402/3cf88052/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
