[QGIS-Developer] GSoC 2019 for QGIS 3D Improvement Proposal
Ismail Sunni imajimatika at gmail.com
Tue Apr 2 01:53:47 PDT 2019
Hi Tim,
Nice proposal Sunni! On the Mac the 3d window is a bit of a pain because it
> is a dock window so cannot be maximised easily and when you do resize it it
> tends to dock into the main window so it always makes it a bit clunky in
> demos. It would be really nice if it either replaced the main 2d map canvas
> or was possible to use it as a normal window instead of a dock widget so
> you can easily maximise it.
Ah really? I can't remember get that issue in Mac before. (un)fortunately,
I am not using Mac anymore, so I am not sure if can help with that. Perhaps
Peter can check it :)
Oh and then please implement some kind of star wars tie-fighter vs x-wind
> chase through my neighbourhood game as an Easter egg in it :-)
Haha, nice idea! Let me check if I prefer star wars or Avengers :D
Thanks also for your comment in the Google Docs.
Best Regards
> it is a dock window so cannot be maximised easily and when you do resize it
> it tends to dock into the main window so it always makes it a bit clunky in
> Regards
> Tim
> On 01 Apr 2019, at 14:26, Ismail Sunni <imajimatika at gmail.com> wrote:
> HI Mathieu
> Regarding on-screen navigation, it'd be good to think of an implementation
>> that would work for both 2D as well as 3D map canvases when conceptualizing
>> the way ahead (I'm not suggesting you implement this as part of this GSoC
>> plan, just seeding the idea as it might shape way you move forward). It'd
>> be useful in a few places across QGIS to have some ultra basic zooming and
>> panning controls attached to a qgsmapcanvas.
> Hmm, yeah, I will think about it in the design. I agree, if it can be used
> on other part, it will be better for sure.
>  Hi Nyall,
> Great proposal Ismail -- all these features would be lovely to see!
>> Reading over the billboard proposal, I'd strongly suggest that you
>> re-use QGIS marker symbology here to render the actual billboard
>> content. Amongst other benefits, this would allow re-use of identical
>> symbols between 2d and 3d maps.
>> Best of luck with the coding!
> As Martin said, it's a good point. I will be happy to re-use existing
> code, I think it's a win-win solution.
> Thanks, Nyall
> Hi Andreas
>> Hi Ismail,
>> Looks nice - thanks for the proposal. Hopefully it will be accepted!
>> I'd love to see all of these improvements, esp. the billboard ones -
>> because currently there is no way to properly label something in 3d.
>> I added a suggestion for the billboards: Allow leader lines between the
>> original point feature and the billboard location above the point feature,
>> with a configurable vertical offset (best also data-defined). It would help
>> better locate the position of the actual feature that is labeled.
>> There are two other ideas regarding QGIS 3D:
>>    - allow highlighting of objects in 3D when using the Identify tool.
>>    Currently one can pick an object in 3d and query the attributes, but there
>>    is no visual feedback what object was actually selected. perhaps with the
>>    new line rendering that Martin is currently working on, this could be used
>>    to draw a red 3d outline of the object picked?
>>    - allow a per layer (or per category) wireframe mode for 3d polygons
>>    and terrain (in order to be able to look through the terrain or 3d objects).
>> I understand that this would be too much for the GSOC proposal, but
>> nevertheless I would like to mention those here, as I think they are
>> important. I totally understand, of course, that they are too much for the
>> GSOC proposal.
>> Thanks and good luck,
>> Andreas
> Yeah, regarding the billboard, that's one of the common use cases that
> Martin and I discussed. So it's under my radar to have something like that
> in the implementation. Btw, thanks for your comments in the Google Doc.
> Those two ideas are interesting and should be implemented somehow in the
> future. But as you said, perhaps it's too much for the GSoC proposal :). I
> can't promise, but who knows what will happen in the future :)
> I can only add that I am also happy that Ismail would like to
>> participate in GSoC and I hope this proposal will get accepted because
>> the proposal looks great.
> Thanks for your help and guidance, Martin :)
> Best regards
> On Mon, Apr 1, 2019 at 2:39 PM Martin Dobias <wonder.sk at gmail.com> wrote:
>> Hi
>> On Mon, Apr 1, 2019 at 1:11 PM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>> > On Mon, 1 Apr 2019 at 20:28, Ismail Sunni <imajimatika at gmail.com>
>> wrote:
>> > > Dear QGIS developers,
>> > > My name is Ismail Sunni, I am from Indonesia. Currently, I am
>> studying in Germany for my master degree. Since I am now a student, I want
>> to participate in this year Google Summer of Code for QGIS. I am interested
>> to contribute and work on the 3D improvement. It's still young and I think
>> that I can help with making it more complete.
>> > > I have discussed with Martin Dobias for a more detail idea and start
>> my proposal. Now, my proposal is more or less ready (according to me). But
>> it would be better if I get some feedback or suggestions from the QGIS
>> community itself. Since it will give impact to the community.
>> > > If you are interested, you can check my proposal in this URL:
>> https://docs.google.com/document/d/1RcXiEyziQyGurqDGRBN3g-het33liVD81WFjv8qQlt8/edit?usp=sharing
>> > > Please don't be hesitate to make a comment either in this email
>> thread or even in the document itself.
>> That's a good point!
>> Cheers
>> Martin
> Ismail Sunni
> ismailsunni.wordpress.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> I'd love to connect. Here's my calendar link
> <https://calendly.com/timlinux> to make finding time easy.
Ismail Sunni
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190402/ee823c23/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190402/ee823c23/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
