[QGIS-Developer] GDAL and microstation dgn v8 files... Teiga ?
Andreas Neumann a.neumann at carto.net
Wed Apr 3 05:11:45 PDT 2019
Hi Richard,
Interesting topic!
Just for the reference - I think about 3-4 years ago we discussed the
same thing: using Teigha for reading/writing dxf and dwg.
Back then, I was suggesting the exact same thing like you: using Teigha
- but due to the proprietary license and packaging issues, there was a
lot of opposition towards using Teigha. You have to be a member in the
OpenDesignAlliance and pay a membership fee for being able to
distribute/package the Teigha libraries.
We even did a crowd funding for dxf/dwg support back then:
http://blog.qgis.org/2015/12/08/crowd-funding-project-for-reading-cad-documents-in-qgis/
During that project it was decided to use the libdxfrw library instead
of Teigha. I believe that Jürgen forked and/or improved that library a
lot during the project.
Jürgen can tell you all the details about it.
Greetings,
Andreas
Am 03.04.19 um 11:51 schrieb Even Rouault:
> On mercredi 3 avril 2019 11:32:52 CEST Richard Duivenvoorde wrote:
>> Hi,
>> Here in NL a lot of municipalities still work with Microstation, so
>> dgn-files are a common format to use.
>> FME is capable of converting dgn to whatever format.
>> But we just found that gdal also has a dngv8 driver [0], but it needs to
>> be build against the Teiga driver.
>> QGIS can import autocat dwg/dxf files, I forgot what lib was used for that.
>> Anybody experience with building GDAL with Teiga?
> For Linux, use the following switches for configure:
>    --with-teigha=path Include Teigha DWG/DGN support
>    --with-teigha-plt=platform Teigha platform
> Like:
> --with-teigha=$HOME/Teigha_lnxX64_5.3dll --with-teigha-plt=lnxX64_5.3dll
> For Windows, locate the TD_ variables in nmake.opt and tweak them.
>> BUT: want/could we use this to create a QGIS which is capable of loading
>> dgn or importing files?
> Sure, that works (except automatic styling) if you use a GDAL with Teigha
> support
>> Or is there an licensing or technical problem?
> No technical problem per se. Regarding licensing, Teigha is of course
> proprietary. I don't recall the terms, but I guess QGIS.org or any other
> distributing entitee would have to pay a fee to be able to redistribute a
> plugin using their SDK.
> Even
More information about the QGIS-Developer mailing list
