[QGIS-Developer] Bug #21460?
DelazJ
delazj at gmail.com
Tue Apr 9 01:42:06 PDT 2019
Le mar. 9 avr. 2019 à 10:25, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> On 09/04/2019 03.41, Nyall Dawson wrote:
> > If you can suggest any ways to improve the wording of that post (while
> > keep the core message intact), please let me know.
> >>>> On Mon, Apr 8, 2019 at 4:30 AM Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> >>>>> may I suggest you an interesting read?
> https://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis/
> I want to second Cory, to me it also feels a little rude to tell a
> 'user' (not a developer) to try to code or pay for a dev. And I'm a
> dutchie, known for their blunt talk :-)
> @Nyall: in my opinion your followup article:
> http://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis-a-follow-up/
> has a better 'tone' for non developers.
> We should probably mix your followup article with the first one and put
> it in the website (in the 'user' section) so it is translatable, so
> translators can maybe even add more 'cultural politness' to it if needed?
> Just for information, I opened weeks ago an issue report for this:
https://github.com/qgis/QGIS-Website/issues/611
Harrissou
> WHO wants to do that (you can earn karma points if you do this !!)??
> We should also make clear that it IS OK to ask for the community to have
> a look at the an issue which makes your(!) live a hell. But also make it
> clear that to be fair your problems are not always the problems of
> somebody else. Same goes for commercial software by the way, only they
> are not as transparent as we are. And that we are humans with not enough
> time to solve all the problems in the world.
> STILL I'm not sure what the right tone is to tell people to read such a
> text though... people (me included!) will feel a little offended anywat
> when not helped but sent to a page to read what they should do...
> I think Geoserver does a good job:
> https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
> And Ian's talk: (though it can maybe be polished a little):
> https://www.ianturton.com/talks/foss4g.html#/how-to-earn-support
> @Cory: please stay on the good side :-)
> May I suggest to make your bug report even better by adding data and
> instructions so for an average developer, it is 10 minutes work to
> replicate your issue? Or should we just create the table and start
> editing? If so please add some steps. For example some googling revealed
> to me that I need: "CREATE EXTENSION IF NOT EXISTS "uuid-ossp";" to use
> the uuid_generate_v4() function you use?
> Also make sure it is actually a QGIS problem, looking into it, it is.
> But it is also a data-schema issue, as you define the problematic
> columns as:
> predecessors uuid[] DEFAULT ARRAY[]::uuid[],
> And the "uuid[]" is not a very common type in the gis world.
> If I'm correct '{""}' (what QGIS now uses for NULL values if the column
> has an array type) is a textual representation of an array with one
> string in it. Would it be better to do '{null}' or even '{}' instead?
> Can you try to create an update query with '{null}' and '{}' values in
> the empty array fields?
> And add these queriies to the bug report?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/30f7fb7e/attachment.html>
