[QGIS-Developer] Bug #21460?
Paolo Cavallini
cavallini at faunalia.it
Tue Apr 9 02:12:47 PDT 2019
Agreed, thanks Richard for the link, and Nyall for writing the article.
Il 9 aprile 2019 10:25:49 CEST, Richard Duivenvoorde <rdmailings at duif.net> ha scritto:
>On 09/04/2019 03.41, Nyall Dawson wrote:
>> If you can suggest any ways to improve the wording of that post
>(while
>> keep the core message intact), please let me know.
>>>>> On Mon, Apr 8, 2019 at 4:30 AM Paolo Cavallini
><cavallini at faunalia.it> wrote:
>>>>>> may I suggest you an interesting read?
>https://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis/
>I want to second Cory, to me it also feels a little rude to tell a
>'user' (not a developer) to try to code or pay for a dev. And I'm a
>dutchie, known for their blunt talk :-)
>@Nyall: in my opinion your followup article:
>http://nyalldawson.net/2016/08/how-to-effectively-get-things-changed-in-qgis-a-follow-up/
>has a better 'tone' for non developers.
>We should probably mix your followup article with the first one and put
>it in the website (in the 'user' section) so it is translatable, so
>translators can maybe even add more 'cultural politness' to it if
>needed?
>WHO wants to do that (you can earn karma points if you do this !!)??
>We should also make clear that it IS OK to ask for the community to
>have
>a look at the an issue which makes your(!) live a hell. But also make
>it
>clear that to be fair your problems are not always the problems of
>somebody else. Same goes for commercial software by the way, only they
>are not as transparent as we are. And that we are humans with not
>enough
>time to solve all the problems in the world.
>STILL I'm not sure what the right tone is to tell people to read such a
>text though... people (me included!) will feel a little offended anywat
>when not helped but sent to a page to read what they should do...
>I think Geoserver does a good job:
>https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
>And Ian's talk: (though it can maybe be polished a little):
>https://www.ianturton.com/talks/foss4g.html#/how-to-earn-support
>@Cory: please stay on the good side :-)
>May I suggest to make your bug report even better by adding data and
>instructions so for an average developer, it is 10 minutes work to
>replicate your issue? Or should we just create the table and start
>editing? If so please add some steps. For example some googling
>revealed
>to me that I need: "CREATE EXTENSION IF NOT EXISTS "uuid-ossp";" to use
>the uuid_generate_v4() function you use?
>Also make sure it is actually a QGIS problem, looking into it, it is.
>But it is also a data-schema issue, as you define the problematic
>columns as:
>predecessors uuid[] DEFAULT ARRAY[]::uuid[],
>And the "uuid[]" is not a very common type in the gis world.
>If I'm correct '{""}' (what QGIS now uses for NULL values if the column
>has an array type) is a textual representation of an array with one
>string in it. Would it be better to do '{null}' or even '{}' instead?
>Can you try to create an update query with '{null}' and '{}' values in
>the empty array fields?
>And add these queriies to the bug report?
>Regards,
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/24ca2670/attachment-0001.html>
