[QGIS-Developer] Bug #21460?
Jürgen E. Fischer
jef at norbit.de
Tue Apr 9 02:35:40 PDT 2019
Hi Richard,
On Tue, 09. Apr 2019 at 10:25:49 +0200, Richard Duivenvoorde wrote:
> predecessors uuid[] DEFAULT ARRAY[]::uuid[],
> And the "uuid[]" is not a very common type in the gis world.
> If I'm correct '{""}' (what QGIS now uses for NULL values if the column
> has an array type) is a textual representation of an array with one
> string in it. Would it be better to do '{null}' or even '{}' instead?
> Can you try to create an update query with '{null}' and '{}' values in
> the empty array fields?
> And add these queriies to the bug report?
What I found looking into a fix for that that is that we also represent json as
map (the table also has json), like hstores.
And later produce hstores from maps - which is obviously isn't json. That
could be changed by simply applying to_json on the produced hstore when
inserting or updating.
Doing that I got doubts about the current implementation as hstores apparently
can only be simple key/value maps and cannot - unlike json - be nested.
So nested json data might not currently read correctly either and we should
better be using text instead of a map for json or check whether if our support
for maps in the ui consideres nested or make it configurable how json is
handled.
But that's where I left off.
Jürgen
PS: That was after the initial gentle ping - if it started like the second
response, I might not have looked at it at all - although that effectively
doesn't make much difference.
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/1183582a/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/1183582a/attachment.ksh>
