[QGIS-Developer] QGIS-Server: filter by categories in an OGC compatible way
    Andreas Neumann
    a.neumann at carto.net
    Tue Apr  9 12:31:41 PDT 2019
Hi Jonathan,
I am aware about the limit in GET requests.
Are you sure that WMS servers don't support POST requests?
Some Google hits suggest otherwise
Geoserver:
https://anitagraser.com/2010/06/09/getmap-from-geoserver-using-http-post/
UMN:
https://gis.stackexchange.com/questions/232215/mapserver-wms-http-post-requests
I am pretty sure that QGIS Server also allows POST requests, but I may
be wrong.
Andreas
Am 09.04.19 um 19:09 schrieb Jonathan Moules:
> Hi Andreas,
> Another problem you may hit - the link below is hitting it being ~2300
> chars - URL's (and thus GET requests) cannot reliably be more than
> about 2000 characters long. At that point you need to shift over to
> POST requests (and I think GetMap is GET only...).
> https://stackoverflow.com/questions/417142/what-is-the-maximum-length-of-a-url-in-different-browsers
> Cheers,
> Jonathan
> On 2019-04-09 16:07, Andreas Neumann wrote:
>> Hi Paul
>> Thanks - now I know that I have to use SLD_BODY for the case where the
>> SLD is in the URL.
>> Another QGIS-Server specific question:
>> Can I count on it that the SLD output by QGIS server with the GetStyles
>> request can also be consumed again by QGIS server? What about complex
>> styles (e.g. something with a style that can't easily be represented by
>> SLD). If I first consume the styles from QGIS server, then filter and
>> send back, would the complex styles potentially be lost/destroyed?
>> Again: our intent here is merely to filter categories, not to change the
>> styles.
>> Thanks,
>> Andreas
>> On 2019-04-09 16:28, pblottiere wrote:
>>> Hi Andreas,
>>>> Can you point me to an example how to create a valid GetMap request
>>>> with an SLD submitted?
>>> There's a basic example in unit tests:
>>> https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsserver_wms_getmap.py#L1309-L1325
>>> Regards,
>>> Paul
>>> On 4/9/19 4:14 PM, Andreas Neumann wrote:
>>> Hi,
>>> I did some test:
>>> Here is a long URL with the SLD (originally sent by QGIS server,
>>> stripped away some RULES manually) and sending it back in a GetMap
>>> request:
>> https://services.geo.zg.ch/ows-oereb/Grundwasserschutz?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=2682932,1225299,2684213,1226054&CRS=EPSG:2056&WIDTH=1615&HEIGHT=952&LAYERS=ch.zg.grundwasserschutz.gwszonen&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE&SLD=%3CStyledLayerDescriptor+xmlns%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22+xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22+xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22+xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld+http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.1.0%2FStyledLayerDescriptor.xsd%22+xmlns%3Ase%3D%22http%3A%2F%2Fwww.opengis.net%2Fse%22+version%3D%221.1.0%22+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A+%3CNamedLayer%3E%0D%0A++%3Cse%3AName%3Ech.zg.grundwasserschutz.gwszonen%3C%2Fse%3AName%3E%0D%0A++%3CUserStyle%3E%0D%0A+++%3Cse%3AName%3Edefault%3C%2Fse%3AName%3E%0D%0A+++%3Cse%3AFeatureTypeStyle%3E%0D%0A++++%3Cs
>> e%3ARule%3E%0D%0A+++++%3Cse%3AName%3EGrundwasserschutzzone+S1%3C%2Fse%3AName%3E%0D%0A+++++%3Cse%3ADescription%3E%0D%0A++++++%3Cse%3ATitle%3EGrundwasserschutzzone+S1%3C%2Fse%3ATitle%3E%0D%0A+++++%3C%2Fse%3ADescription%3E%0D%0A+++++%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A++++++%3Cogc%3APropertyIsEqualTo%3E%0D%0A+++++++%3Cogc%3APropertyName%3Etyp_code%3C%2Fogc%3APropertyName%3E%0D%0A+++++++%3Cogc%3ALiteral%3ES1%3C%2Fogc%3ALiteral%3E%0D%0A++++++%3C%2Fogc%3APropertyIsEqualTo%3E%0D%0A+++++%3C%2Fogc%3AFilter%3E%0D%0A+++++%3Cse%3APolygonSymbolizer%3E%0D%0A++++++%3Cse%3AFill%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22fill%22%3E%23003bb3%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AFill%3E%0D%0A++++++%3Cse%3AStroke%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke%22%3E%23000080%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-width%22%3E1%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-linej
>> oin%22%3Ebevel%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AStroke%3E%0D%0A+++++%3C%2Fse%3APolygonSymbolizer%3E%0D%0A++++%3C%2Fse%3ARule%3E%0D%0A+++%3C%2Fse%3AFeatureTypeStyle%3E%0D%0A++%3C%2FUserStyle%3E%0D%0A+%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E
>>> The response is:
>>> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
>>> version="1.3.0">
>>> <ServiceException code="Invalid Parameter"> SLD
>>> ('<StyledLayerDescriptor xmlns="http://www.opengis.net/sld" [1]
>>> xmlns:xlink="http://www.w3.org/1999/xlink" [2]
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" [3]
>>> xsi:schemaLocation="http://www.opengis.net/sld
>>> http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd" [4]
>>> xmlns:se="http://www.opengis.net/se" [5] version="1.1.0"
>>> xmlns:ogc="http://www.opengis.net/ogc" [6]> <NamedLayer>
>>> <se:Name>ch.zg.grundwasserschutz.gwszonen</se:Name> <UserStyle>
>>> <se:Name>default</se:Name> <se:FeatureTypeStyle> <se:Rule>
>>> <se:Name>Grundwasserschutzzone S1</se:Name> <se:Description>
>>> <se:Title>Grundwasserschutzzone S1</se:Title> </se:Description>
>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc" [6]>
>>> <ogc:PropertyIsEqualTo>
>>> <ogc:PropertyName>typ_code</ogc:PropertyName>
>>> <ogc:Literal>S1</ogc:Literal> </ogc:PropertyIsEqualTo> </ogc:Filter>
>>> <se:PolygonSymbolizer> <se:Fill> <se:SvgParameter
>>> name="fill">#003bb3</se:SvgParameter> </se:Fill> <se:Stroke>
>>> <se:SvgParameter
>> name="stroke">#000080</se:SvgParameter> <se:SvgParameter
>> name="stroke-width">1</se:SvgParameter> <se:SvgParameter
>> name="stroke-linejoin">bevel</se:SvgParameter> </se:Stroke>
>> </se:PolygonSymbolizer> </se:Rule> </se:FeatureTypeStyle>
>> </UserStyle> </NamedLayer> </StyledLayerDescriptor>') cannot be
>> converted into QString
>>> </ServiceException> </ServiceExceptionReport>
>>> So apparently the SLD cannot be converted to a QString. Is my
>>> encoding in the URL above wrong or am I missing a required
>>> additional parameter?
>>> Thanks a lot, Andreas
>>> On 2019-04-09 15:38, Andreas Neumann wrote:
>>> Hi,
>>> Does QGIS-Server support SLD styles to filter away RULEs in a GetMap
>>> Request?
>>> I would assume, yes, but in what encoding would I submit such an SLD
>>> in a GET request? I know that one should rather use POST reqests for
>>> such long parameters, but for experimenting, it would be ok to use GET.
>>> The idea would be to allow users to enable/disable categories within
>>> a given layer.
>>> The WMS client would first request the available rules with a
>>> GetStyles command (that part works fine) and would then filter the
>>> RULE (strip away the unwanted RULEs) and resubmit the GetMap with an
>>> SLD. Does that work with QGIS server?
>>> I know that one can also use the FILTER parameter, but we want to do
>>> it in an OGC compatible way, since the client being developed should
>>> work with any OGC compatible WMS server.
>>> Thanks for your reply,
>>> Andreas _______________________________________________
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Links:
>> [1] http://www.opengis.net/sld
>> [2] http://www.w3.org/1999/xlink
>> [3] http://www.w3.org/2001/XMLSchema-instance
>> [4]
>> http://www.opengis.net/sldhttp://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd
>> [5] http://www.opengis.net/se
>> [6] http://www.opengis.net/ogc
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190409/5e276e0c/attachment-0001.html>
