[QGIS-Developer] QGIS-Server: filter by categories in an OGC compatible way
Jonathan Moules
jonathan-lists at lightpear.com
Tue Apr 9 12:48:10 PDT 2019
Hi Andrea,
Just checked the WMS 1.3.0 spec:
"HTTP supports two request methods: GET and POST. One or both of these
methods may be offered by a server,
and the use of the Online Resource URL differs in each case. Support for
the GET method is mandatory; support
for the POST method is optional."
The GetCaps document should indicate whether POST is supported.
So I was wrong, they can be GET, but it's not guaranteed. Sorry about
that, thanks for checking!
Cheers,
Jonathan
On 2019-04-09 20:31, Andreas Neumann wrote:
> Hi Jonathan,
> I am aware about the limit in GET requests.
> Are you sure that WMS servers don't support POST requests?
> Some Google hits suggest otherwise
> Geoserver:
> https://anitagraser.com/2010/06/09/getmap-from-geoserver-using-http-post/
> UMN:
> https://gis.stackexchange.com/questions/232215/mapserver-wms-http-post-requests
> I am pretty sure that QGIS Server also allows POST requests, but I may
> be wrong.
> Andreas
> Am 09.04.19 um 19:09 schrieb Jonathan Moules:
>> Hi Andreas,
>> Another problem you may hit - the link below is hitting it being
>> ~2300 chars - URL's (and thus GET requests) cannot reliably be more
>> than about 2000 characters long. At that point you need to shift over
>> to POST requests (and I think GetMap is GET only...).
>> https://stackoverflow.com/questions/417142/what-is-the-maximum-length-of-a-url-in-different-browsers
>> Cheers,
>> Jonathan
>> On 2019-04-09 16:07, Andreas Neumann wrote:
>>> Hi Paul
>>> Thanks - now I know that I have to use SLD_BODY for the case where the
>>> SLD is in the URL.
>>> Another QGIS-Server specific question:
>>> Can I count on it that the SLD output by QGIS server with the GetStyles
>>> request can also be consumed again by QGIS server? What about complex
>>> styles (e.g. something with a style that can't easily be represented by
>>> SLD). If I first consume the styles from QGIS server, then filter and
>>> send back, would the complex styles potentially be lost/destroyed?
>>> Again: our intent here is merely to filter categories, not to change
>>> the
>>> styles.
>>> Thanks,
>>> Andreas
>>> On 2019-04-09 16:28, pblottiere wrote:
>>>> Hi Andreas,
>>>>> Can you point me to an example how to create a valid GetMap
>>>>> request with an SLD submitted?
>>>> There's a basic example in unit tests:
>>>> https://github.com/qgis/QGIS/blob/master/tests/src/python/test_qgsserver_wms_getmap.py#L1309-L1325
>>>> Regards,
>>>> Paul
>>>> On 4/9/19 4:14 PM, Andreas Neumann wrote:
>>>> Hi,
>>>> I did some test:
>>>> Here is a long URL with the SLD (originally sent by QGIS server,
>>>> stripped away some RULES manually) and sending it back in a GetMap
>>>> request:
>>> https://services.geo.zg.ch/ows-oereb/Grundwasserschutz?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=2682932,1225299,2684213,1226054&CRS=EPSG:2056&WIDTH=1615&HEIGHT=952&LAYERS=ch.zg.grundwasserschutz.gwszonen&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE&SLD=%3CStyledLayerDescriptor+xmlns%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld%22+xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22+xmlns%3Axsi%3D%22http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance%22+xsi%3AschemaLocation%3D%22http%3A%2F%2Fwww.opengis.net%2Fsld+http%3A%2F%2Fschemas.opengis.net%2Fsld%2F1.1.0%2FStyledLayerDescriptor.xsd%22+xmlns%3Ase%3D%22http%3A%2F%2Fwww.opengis.net%2Fse%22+version%3D%221.1.0%22+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A+%3CNamedLayer%3E%0D%0A++%3Cse%3AName%3Ech.zg.grundwasserschutz.gwszonen%3C%2Fse%3AName%3E%0D%0A++%3CUserStyle%3E%0D%0A+++%3Cse%3AName%3Edefault%3C%2Fse%3AName%3E%0D%0A+++%3Cse%3AFeatureTypeStyle%3E%0D%0A++++%3Cs
>>> e%3ARule%3E%0D%0A+++++%3Cse%3AName%3EGrundwasserschutzzone+S1%3C%2Fse%3AName%3E%0D%0A+++++%3Cse%3ADescription%3E%0D%0A++++++%3Cse%3ATitle%3EGrundwasserschutzzone+S1%3C%2Fse%3ATitle%3E%0D%0A+++++%3C%2Fse%3ADescription%3E%0D%0A+++++%3Cogc%3AFilter+xmlns%3Aogc%3D%22http%3A%2F%2Fwww.opengis.net%2Fogc%22%3E%0D%0A++++++%3Cogc%3APropertyIsEqualTo%3E%0D%0A+++++++%3Cogc%3APropertyName%3Etyp_code%3C%2Fogc%3APropertyName%3E%0D%0A+++++++%3Cogc%3ALiteral%3ES1%3C%2Fogc%3ALiteral%3E%0D%0A++++++%3C%2Fogc%3APropertyIsEqualTo%3E%0D%0A+++++%3C%2Fogc%3AFilter%3E%0D%0A+++++%3Cse%3APolygonSymbolizer%3E%0D%0A++++++%3Cse%3AFill%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22fill%22%3E%23003bb3%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AFill%3E%0D%0A++++++%3Cse%3AStroke%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke%22%3E%23000080%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-width%22%3E1%3C%2Fse%3ASvgParameter%3E%0D%0A+++++++%3Cse%3ASvgParameter+name%3D%22stroke-linej
>>> oin%22%3Ebevel%3C%2Fse%3ASvgParameter%3E%0D%0A++++++%3C%2Fse%3AStroke%3E%0D%0A+++++%3C%2Fse%3APolygonSymbolizer%3E%0D%0A++++%3C%2Fse%3ARule%3E%0D%0A+++%3C%2Fse%3AFeatureTypeStyle%3E%0D%0A++%3C%2FUserStyle%3E%0D%0A+%3C%2FNamedLayer%3E%0D%0A%3C%2FStyledLayerDescriptor%3E
>>>> The response is:
>>>> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc"
>>>> version="1.3.0">
>>>> <ServiceException code="Invalid Parameter"> SLD
>>>> ('<StyledLayerDescriptor xmlns="http://www.opengis.net/sld" [1]
>>>> xmlns:xlink="http://www.w3.org/1999/xlink" [2]
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" [3]
>>>> xsi:schemaLocation="http://www.opengis.net/sld
>>>> http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd" [4]
>>>> xmlns:se="http://www.opengis.net/se" [5] version="1.1.0"
>>>> xmlns:ogc="http://www.opengis.net/ogc" [6]> <NamedLayer>
>>>> <se:Name>ch.zg.grundwasserschutz.gwszonen</se:Name> <UserStyle>
>>>> <se:Name>default</se:Name> <se:FeatureTypeStyle> <se:Rule>
>>>> <se:Name>Grundwasserschutzzone S1</se:Name> <se:Description>
>>>> <se:Title>Grundwasserschutzzone S1</se:Title> </se:Description>
>>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc" [6]>
>>>> <ogc:PropertyIsEqualTo>
>>>> <ogc:PropertyName>typ_code</ogc:PropertyName>
>>>> <ogc:Literal>S1</ogc:Literal> </ogc:PropertyIsEqualTo>
>>>> </ogc:Filter> <se:PolygonSymbolizer> <se:Fill> <se:SvgParameter
>>>> name="fill">#003bb3</se:SvgParameter> </se:Fill> <se:Stroke>
>>>> <se:SvgParameter
>>> name="stroke">#000080</se:SvgParameter> <se:SvgParameter
>>> name="stroke-width">1</se:SvgParameter> <se:SvgParameter
>>> name="stroke-linejoin">bevel</se:SvgParameter> </se:Stroke>
>>> </se:PolygonSymbolizer> </se:Rule> </se:FeatureTypeStyle>
>>> </UserStyle> </NamedLayer> </StyledLayerDescriptor>') cannot be
>>> converted into QString
>>>> </ServiceException> </ServiceExceptionReport>
>>>> So apparently the SLD cannot be converted to a QString. Is my
>>>> encoding in the URL above wrong or am I missing a required
>>>> additional parameter?
>>>> Can you point me to an example how to create a valid GetMap request
>>>> Thanks a lot, Andreas
>>>> On 2019-04-09 15:38, Andreas Neumann wrote:
>>>> Hi,
>>>> Does QGIS-Server support SLD styles to filter away RULEs in a
>>>> GetMap Request?
>>>> I would assume, yes, but in what encoding would I submit such an
>>>> SLD in a GET request? I know that one should rather use POST
>>>> reqests for such long parameters, but for experimenting, it would
>>>> be ok to use GET.
>>>> The idea would be to allow users to enable/disable categories
>>>> within a given layer.
>>>> The WMS client would first request the available rules with a
>>>> GetStyles command (that part works fine) and would then filter the
>>>> RULE (strip away the unwanted RULEs) and resubmit the GetMap with
>>>> an SLD. Does that work with QGIS server?
>>>> I know that one can also use the FILTER parameter, but we want to
>>>> do it in an OGC compatible way, since the client being developed
>>>> should work with any OGC compatible WMS server.
>>>> Thanks for your reply,
>>>> Andreas _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Links:
>>> [1] http://www.opengis.net/sld
>>> [2] http://www.w3.org/1999/xlink
>>> [3] http://www.w3.org/2001/XMLSchema-instance
>>> [4]
>>> http://www.opengis.net/sldhttp://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd
>>> [5] http://www.opengis.net/se
>>> [6] http://www.opengis.net/ogc
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
