[QGIS-Developer] Project files translation
Matthias Kuhn matthias at opengis.ch
Fri Apr 12 03:00:29 PDT 2019
Hi Matteo
On 4/12/19 11:49 AM, Matteo Ghetta wrote:
> Hi all,
> playing with the i18n translation of projects I discovered some
> (unwanted?) things:
> * works only for qgs and not qgz, right? Is this a bug or a feature request?
Correct. The main open question there is if the side car files should be
inside the qgz or next to it. Both have advantages and disadvantages and
therefore it was left out of the first implementation for a follow up
step with a clearer path.
> * when using a field within an algorithm (e.g. a buffer with variable
> distance) the name displayed are the original and not the translated
What exactly are you referring too here?
In general: everything that is translatable needs to be added one by one
(see https://github.com/qgis/QGIS-Enhancement-Proposals/issues/90) and
will also need to be added incrementally as things appear in the future.
Especially expressions are hard to do.
The focus of the initial project was mainly on forms and legend.
> Is this still a work in progress or should I file a bug/feature request?
There is no work going on right now.
Bests
Matthias
> Thanks
> Matteo
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/22069181/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/22069181/attachment.png>
More information about the QGIS-Developer mailing list
