[QGIS-Developer] GetFeatureInfo: sensitivity on rendered geometry vs original geometry.
René-Luc Dhont
rldhont at gmail.com
Fri Apr 12 06:53:10 PDT 2019
Hi Andreas,
I think QGIS Server has to use the rendered geometries to identify Feature.
Is it possible to get the point layer to polygon rendred layer ?
Regards,
René-Luc
Le 12/04/2019 à 15:43, Andreas Neumann a écrit :
> Hi,
> I'd like to discuss an issue with GetFeatureInfo that we have with
> point symbols.
> (Point) symbols can have different sizes (sometimes rather large),
> different anchor points and sometimes even with offset away from the
> original feature geometry. Often, the rendering of the point symbol
> differs substantially from the original point geometry.
> Now, our issue is that GetFeatureInfo often fails miserably in such
> cases. People try to click on the visible symbol, which doesn't
> correspond to the original geometry.
> One such example WMS:
> https://services.geo.zg.ch/ows/Abfallsammelstellen
> The symbols are rather large, but the anchor point is at the bottom of
> the symbol. Users now think that they can click anywhere on the
> symbol, but in fact they can only click on the original geometry at
> the very bottom of the symbol, taking into account
> the FI_POINT_TOLERANCE parameter.
> Things get even worse when one wants to identify points that are
> displayed using the point displacement renderer. There, GetFeatureInfo
> is only sensitive on the center point, and not at all at the rendered
> points at a completely different position.
> Now my question: could we improve QGIS server that GetFeatureInfo
> responds to the bounding boxes of the rendered geometries (as opposed
> to the raw geometries), taking into account sizes, offsets, etc.
> Would this be technically possible?
> Would others also think that this is useful to have?
> Or would this even contradict OGC standards?
> Do other WMS servers implement such behaviors (Geoserver, UMN)?
> Thanks for the discussion,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/a7ce05a4/attachment.html>
