[QGIS-Developer] GetFeatureInfo: sensitivity on rendered geometry vs original geometry.
Alessandro Pasotti
apasotti at gmail.com
Fri Apr 12 06:56:22 PDT 2019
On Fri, Apr 12, 2019 at 3:53 PM René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Andreas,
> I think QGIS Server has to use the rendered geometries to identify Feature.
Hi René,
Yeah, I also though that's the only solution, what scares me is the
performances cost, because we would need to render and check each layer
individually.
> Is it possible to get the point layer to polygon rendred layer ?
I don't follow you, can you explain what's in your mind?
> Regards,
> René-Luc
> Le 12/04/2019 à 15:43, Andreas Neumann a écrit :
> Hi,
> I'd like to discuss an issue with GetFeatureInfo that we have with point
> symbols.
> (Point) symbols can have different sizes (sometimes rather large),
> different anchor points and sometimes even with offset away from the
> original feature geometry. Often, the rendering of the point symbol differs
> substantially from the original point geometry.
> Now, our issue is that GetFeatureInfo often fails miserably in such cases.
> People try to click on the visible symbol, which doesn't correspond to the
> original geometry.
> One such example WMS:
> https://services.geo.zg.ch/ows/Abfallsammelstellen
> The symbols are rather large, but the anchor point is at the bottom of the
> symbol. Users now think that they can click anywhere on the symbol, but in
> fact they can only click on the original geometry at the very bottom of the
> symbol, taking into account the FI_POINT_TOLERANCE parameter.
> Things get even worse when one wants to identify points that are displayed
> using the point displacement renderer. There, GetFeatureInfo is only
> sensitive on the center point, and not at all at the rendered points at a
> completely different position.
> Now my question: could we improve QGIS server that GetFeatureInfo responds
> to the bounding boxes of the rendered geometries (as opposed to the raw
> geometries), taking into account sizes, offsets, etc.
> Would this be technically possible?
> Would others also think that this is useful to have?
> Or would this even contradict OGC standards?
> Do other WMS servers implement such behaviors (Geoserver, UMN)?
> Thanks for the discussion,
> Andreas
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/1916fe09/attachment-0001.html>
