[QGIS-Developer] GetFeatureInfo: sensitivity on rendered geometry vs original geometry.
Andrea Aime
andrea.aime at geo-solutions.it
Fri Apr 12 07:34:50 PDT 2019
On Fri, Apr 12, 2019 at 3:44 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Or would this even contradict OGC standards?
On the contrary, I believe a behavior that does not use map rendering to
answer the questions contradicts the standard,
since GetFeaureInfo should return what a user clicked on a particular pixel
in the rendered map
> Do other WMS servers implement such behaviors (Geoserver, UMN)?
GeoServer does the rendered version by default, but it's possible to turn
that off and go back the on the bbox based engine
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/d3684456/attachment.html>
