[QGIS-Developer] GetFeatureInfo: sensitivity on rendered geometry vs original geometry.
Régis Haubourg
regis.haubourg at gmail.com
Fri Apr 12 09:03:37 PDT 2019
I think Paul and Eric have been working on that issue. I'm adding them in
the loop here.
Regards
Régis
Le ven. 12 avr. 2019 à 16:46, René-Luc Dhont <rldhont at gmail.com> a écrit :
> Hi
> Le 12/04/2019 à 16:05, Andreas Neumann a écrit :
> On 2019-04-12 15:53, René-Luc Dhont wrote:
> Hi Andreas,
> I think QGIS Server has to use the rendered geometries to identify Feature.
> yes
> Is it possible to get the point layer to polygon rendred layer ?
> Like Alessandro, I also don't understand this statement. Do you say that I
> should convert my point layer to a polygon layer representing the rendered
> bounding box? This would be quite difficult for our users.
> Andreas
> The idea is how QGIS can convert point layer to polygon layer
> corresponding to bbox symbol to get feature information.
> In QGIS Server, GetFeatureInfo is a simple GetFeature based on Extent. Is
> it possible to do the same but based on rendering ?
> René-Luc
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190412/a1d485f1/attachment-0001.html>
