[QGIS-Developer] Globally setting FI_POINT_TOLERANCE on QGIS server
Andreas Neumann a.neumann at carto.net
Tue Apr 16 06:46:41 PDT 2019
I wonder if it is possible to globally set/influence the
FI_POINT_TOLERANCE in QGIS server?
We'd like to configure QGIS server such, that by default it is a bit
more tolerant (using a larger search radius) for point features.
I know that the client can set the FI_POINT_TOLERANCE on GetFeatureInfo
request, but what if the client doesn't know about QGIS and these
special parameters?
Could this be set globally in QGIS server by an environment variable?
Thanks for your reply and greetings,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190416/e9616348/attachment.html>
More information about the QGIS-Developer mailing list
