[QGIS-Developer] Globally setting FI_POINT_TOLERANCE on QGIS server
Alessandro Pasotti
apasotti at gmail.com
Tue Apr 16 06:53:19 PDT 2019
On Tue, Apr 16, 2019 at 3:46 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> I wonder if it is possible to globally set/influence
> the FI_POINT_TOLERANCE in QGIS server?
> We'd like to configure QGIS server such, that by default it is a bit more
> tolerant (using a larger search radius) for point features.
> I know that the client can set the FI_POINT_TOLERANCE on GetFeatureInfo
> request, but what if the client doesn't know about QGIS and these special
> parameters?
> Could this be set globally in QGIS server by an environment variable?
No, that's not possible.
Thanks for your reply and greetings,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190416/07c07cf2/attachment.html>
