[QGIS-Developer] Globally setting FI_POINT_TOLERANCE on QGIS server
David Marteau
dmarteau at 3liz.com
Tue Apr 16 07:07:12 PDT 2019
Updated for qgis3: https://github.com/3liz/qgis-wmsGetFeatureInfoPrecision/blob/master/wmsGetFeatureInfoPrecision.py
Warning, because of https://github.com/qgis/QGIS/pull/9773 <https://github.com/qgis/QGIS/pull/9773> configuration located at the project path is not fully supported yet.
David
> Le 16 avr. 2019 à 16:01, René-Luc Dhont <rldhont at gmail.com> a écrit :
> Hi Andreas,
> We have build a plugin for doing so.
> It is available for QGIS 2 and we are working on proting it to QGIS 3.
> https://github.com/3liz/qgis-wmsGetFeatureInfoPrecision <https://github.com/3liz/qgis-wmsGetFeatureInfoPrecision>
> Regards,
> René-Luc
> Le 16/04/2019 à 15:53, Alessandro Pasotti a écrit :
>> On Tue, Apr 16, 2019 at 3:46 PM Andreas Neumann <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>> Hi,
>> I wonder if it is possible to globally set/influence the FI_POINT_TOLERANCE in QGIS server?
>> We'd like to configure QGIS server such, that by default it is a bit more tolerant (using a larger search radius) for point features.
>> I know that the client can set the FI_POINT_TOLERANCE on GetFeatureInfo request, but what if the client doesn't know about QGIS and these special parameters?
>> Could this be set globally in QGIS server by an environment variable?
>> No, that's not possible.
>> Thanks for your reply and greetings,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it/>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190416/2f687a11/attachment.html>
