[QGIS-Developer] Globally setting FI_POINT_TOLERANCE on QGIS server
Andreas Neumann
a.neumann at carto.net
Tue Apr 16 07:27:31 PDT 2019
Hi René-Luc and David,
Excellent - Thanks for providing it. I will test and report back. But I
won't have time to test it before Thursday because I am giving a QGIS
course tomorrow.
Seems like we are all hitting similar issues with QGIS server ;-) good
that there is something we can do about it.
Thanks,
Andreas
On 2019-04-16 16:01, René-Luc Dhont wrote:
> Hi Andreas,
> We have build a plugin for doing so.
> It is available for QGIS 2 and we are working on proting it to QGIS 3.
> https://github.com/3liz/qgis-wmsGetFeatureInfoPrecision
> Regards,
> René-Luc
> Le 16/04/2019 à 15:53, Alessandro Pasotti a écrit :
> On Tue, Apr 16, 2019 at 3:46 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> I wonder if it is possible to globally set/influence the FI_POINT_TOLERANCE in QGIS server?
> We'd like to configure QGIS server such, that by default it is a bit more tolerant (using a larger search radius) for point features.
> I know that the client can set the FI_POINT_TOLERANCE on GetFeatureInfo request, but what if the client doesn't know about QGIS and these special parameters?
> Could this be set globally in QGIS server by an environment variable?
> No, that's not possible.
> Thanks for your reply and greetings,
> Andreas _______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it [1]
Links:
[1] http://www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190416/aa48c924/attachment.html>
