[QGIS-Developer] How calculate sequential values based on spatial pattern
Jorge Gustavo Rocha
jgr at di.uminho.pt
Wed Apr 17 09:18:37 PDT 2019
Hi Ana,
Your question is more related with QGIS usage. This list is mostly for
QGIS development. Can you please use the "QGIS-user" [1] list for this
issue?
In QGIS-user you will get a broader audience of power users that can
recommend you simple tricks (like sorting the points using an expression
on x and y). Here [QGIS-Develpment] you can end by writing C++ code ;-)
Good luck,
Jorge Gustavo
[1] https://lists.osgeo.org/mailman/listinfo/qgis-user
Às 15:03 de 16/04/19, Ana María Munevar Díaz escreveu:
> Hi!
> I need your help. I need to Create a numbers sequentially in a "Points
> shapefile" with a spacial pattern.
> For example, the point number 1 start northwestern and the next numbers
> points will be order from west to east. For the next row (to South)
> going from west to east too.
> And so on, the values points increase to the south. Therefore the last
> point will be in the southeast.
> For now I'm doing manual but it is around 1,000 points!
> I hope that you understand my situation. Can you help me? I could send
> you the shapefile with an example better explained
> Thanks,
> Ana
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
