[QGIS-Developer] Projection issue with QGIS Dev
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Thu Apr 25 03:17:13 PDT 2019
last "building" commit on master with proj6 is
d3f6a5f9be9692c4ce232178df144f64a228955a
Nyall will probably fix master with proj6 next week.
Regards,
Peter
On Thu, Apr 25, 2019 at 12:05 PM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 25/04/2019 03.35, Denis Rouzaud wrote:
> > Nyall is working with proj 6 integration and from what I understood 6.0
> > has unexpected with QGIS, 6.1 (may) should solve the issue.
> > But Nyall would have a more precise explanation I guess.
> I've been building proj6 here with gdal 2.4.
> But (without modifications )I've not been able to build QGIS master with
> it yet.
> Not sure if it is helpfull, both with and without (earlier suggested):
> -DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=1
> or
> -DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=0
> I get:
> /home/richard/git/qgisgdal/src/core/qgscoordinatereferencesystem.cpp: In
> static member function ‘static int
> QgsCoordinateReferenceSystem::syncDatabase()’:
> /home/richard/git/qgisgdal/src/core/qgscoordinatereferencesystem.cpp:2249:3:
> error: ‘projCtx’ was not declared in this scope
> projCtx pContext = pj_ctx_alloc();
> note: suggested alternative: ‘projCtx_t’
> projCtx_t
> Happy to test build if it is helpful, but I'm afraid I cannot be helpful
> with fixing the build though :(
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190425/84dc8b1b/attachment-0001.html>
