[QGIS-Developer] SAGA release 7.3 (new LTR)
Pedro Venâncio pedrongvenancio at gmail.com
Fri Aug 2 08:37:55 PDT 2019
Hi Nyall and Johan,
Alexander Bruy had updated his SAGA provider for Processing to SAGA 7.3.0
already, so it is the best candidate to be merged to core! :)
https://plugins.bruy.me/processing-saga.html
Best regards,
Pedro Venâncio
Nyall Dawson <nyall.dawson at gmail.com> escreveu no dia quinta, 1/08/2019
à(s) 23:23:
> On Fri, 2 Aug 2019 at 05:06, Johan Van de Wauw
> <johan.vandewauw at gmail.com> wrote:
> > Hi all,
> > SAGA has released a 7.3 version at the end of june, and I intend to keep
> a stable branch based on this release, and drop support of the old branch
> (which was not maintained well).
> > I am aware of the next-gen processing plugin at
> > https://plugins.qgis.org/plugins/processing_saga_nextgen/ which now
> targets 7.2, but wonder if we should not consider switching to this version
> also in the normal processing plugin.
> This is great news, thank you so much for this! It will definitely
> make things much easier for users.
> What I'm thinking is that we should make the core plugin handle both
> 2.3 and 7,3, as it's likely to be some time before 7.3 is available on
> all target platforms. The next_gen plugin might be a good starting
> point, but to my knowledge it hasn't been widely tested and I would
> expect there's many algorithms in it which don't work (since they
> haven't been updated from the 2.3 definitions)... So there's quite a
> bit of work for someone to do on the QGIS side.
> This would be a great task for a motivated, knowledgeable SAGA
> processing user to contribute to QGIS. Any volunteers?
> Nyall
> > I'll be at FOSS4G later this month, so perhaps this is a good time to
> implement/discuss some of these changes?
> > Kind regards,
> > Johan
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190802/4bab745a/attachment.html>
More information about the QGIS-Developer mailing list
